terrymason |
Member ![]() ![]() Group: Members Posts: 346 Joined: 23-November 05 From: Virginia Beach Member No.: 5,174 ![]() |
The problem - The car will go very lean around 2500 rpm, as if the pump jets were too small.
History: New fuel pump (3.5 PSI to each carb) 55 idle jets 55 pump jets 140 main jets 175 air correctors These carbs are new to the car, and I'm trying to dial them in. The car is lean when I first start it (16 / 17 on my air / fuel gauge), but then levels out to a nice 14.7 idle when warmed up. While driving, I can give the car 20% or so of the pedal, and drive up to highway speeds nicely, but when I goose it, it will go very lean (18-22 on my gauge) followed by a series of backfires and loss of power. I started off with 35 pump jets, and have moved up to 55s, which appear to be the most popular around here. I've also adjusted the pump jet linkage, from the nut fully loosened, and moved it in as far as it would go before affecting the main throttle shaft (like 60 turns or something). What do you guys think, do I need 75 pump jets? |
terrymason |
well, I've made alot of progress! I have installed new 30 venturis, and re-adjusted the linkage (one side was about vertical, while the other was a an angle). The car no longer backfires, and runs much better, but it does still go lean when switching from idle to main circuit.
I noticed that the auxiliary venturi (the tube over top of the main venturi) don't all match. 3 of them have the number 2 stamped on them, while one has the number 1 on it. I'm assuming that this is a measurement of some sort right? What size should I want? Any idea what this would cause? Thanks guys! It's great to have my car running again! |
Lo-Fi Version | Time is now: 4th July 2025 - 03:21 AM |
