> Points and Dwell setting, Yes I forgot how...I know !!! YOU DUMBASS!
Steve Thacker
post Aug 3 2007, 10:50 AM
UMMMPH Yea Baby Yea ! UMMMPH
I can't for the life of me rember how to set dwell properly on cars. I have been setting points since I was a teenager. I get this thing on a crane optical back when I first bought the car in 2000 and it went belly up last week.
I put in new points, cap, rotor ( non rev limited), condenser, sparkys, wires oh yea a new coil in the car before I began
( back to simple old skool). yea right.... (IMG:style_emoticons/default/dry.gif)
Firing order on wires set to 1-4-3-2 CW.
I set the points to .016 and I can get the car started. I put a digital meter on the
+ and - on the coil and got the car to start with some dizzy turning
( damn it is sensitive).
Well... the dwell on the meter is showing 88.8 and yes it is set on dwell. I go back make sure the point shoe is straddling the lobe on the dizzy shaft and check the gap again. Still at 016. OK I'm good... Then I proceed to start the car up again and get my timing light in place to set the timing. I set the timing light dial to 27 degrees and point it at the timing whole and look for my marks. I have the old lady rev it up to 3500 and hold it steady (great gal she is). (IMG:style_emoticons/default/biggrin.gif)
I look for the white mark as I'm adjusting the dizzy and pull it into view and place it in the V notch. I have her take her foot off the pedal and I take over. Well...the damn car will not rev past 4k when it is floored!
The throttle body butterfly is wide open and the car is laboring.
Fuel pressure is at 29lbs and steady
(Adjusted valves back a year ago and have only put 40 miles on the car)
What gives...am I missing something simple here?
Please help fellas I'm pulling my hair out. Must be halfziemers setting in.
Steve Thacker
post Aug 6 2007, 01:49 PM
Thank you to all who came up with ideas to get my mind churning and yes a big Thank You to the Skipper.
As always, willing to steer us wayward children back onto getting our cars running righteously YESS FRIEEENDS I"M HEEEEALED !
Praise the Skipper and pass the collection plate in his general direction. (IMG:style_emoticons/default/laugh.gif)
Steve Thacker   Points and Dwell setting   Aug 3 2007, 10:50 AM
Bartlett 914   What about the vacuum advance hose. Did you discon...   Aug 3 2007, 11:01 AM
Steve Thacker   What about the vacuum advance hose. Did you disco...   Aug 3 2007, 11:05 AM
tod914   Set it to TDC on the number one cyl. so the lobe o...   Aug 3 2007, 11:02 AM
Steve Thacker   Set it to TDC on the number one cyl. so the lobe ...   Aug 3 2007, 11:07 AM
tod914   you mentioined your dwell is at 88.8 seems abit o...   Aug 3 2007, 11:09 AM
Steve Thacker   you mentioined your dwell is at 88.8 seems abit ...   Aug 3 2007, 11:12 AM
Bartlett 914   Did you replace the spark plug wires? Possibly con...   Aug 3 2007, 11:13 AM
Steve Thacker   Did you replace the spark plug wires? Possibly co...   Aug 3 2007, 11:17 AM
toomanyinkc   Yes, you can set the timing correctly when the dwe...   Aug 3 2007, 11:47 AM
tod914   You change the dwell by readjusting the points. T...   Aug 3 2007, 12:05 PM
Dr Evil   The smaller the gap the longer the dwell (time the...   Aug 3 2007, 12:19 PM
zymurgist   Dr. Evil, Sounds about right to me! I have b...   Aug 3 2007, 12:39 PM
Steve Thacker   Dr. Evil, Sounds about right to me! I have ...   Aug 3 2007, 12:46 PM
Steve Thacker   Sorry, I went in the house to get a samich Well....   Aug 3 2007, 12:40 PM
swl   Is the dwell meter set to v8? Mine has 2 scales on...   Aug 3 2007, 01:00 PM
Steve Thacker   Steve, I looked at the meter and it says it is set...   Aug 3 2007, 01:04 PM
Bartlett 914   Steve, dwell should not change at all with any ...   Aug 3 2007, 01:07 PM
Cap'n Krusty   SEVENTEEN REPLIES AND NOT ONE CORRECT ANSWER! ...   Aug 3 2007, 02:28 PM
Bartlett 914   SEVENTEEN REPLIES AND NOT ONE CORRECT ANSWER...   Aug 3 2007, 03:18 PM
shane   SEVENTEEN REPLIES AND NOT ONE CORRECT ANSWER...   Jul 20 2021, 05:19 PM
shane   SEVENTEEN REPLIES AND NOT ONE CORRECT ANSWER...   Jul 20 2021, 05:22 PM
Steve Thacker   OUCHIE :evilgrin: Thank you skipper for the det...   Aug 3 2007, 02:39 PM
Cap'n Krusty   OUCHIE :evilgrin: Thank you skipper for the de...   Aug 3 2007, 03:13 PM
Steve Thacker   OUCHIE :evilgrin: Thank you skipper for the d...   Aug 3 2007, 03:44 PM
914nerd   Oh krusty one, I may be out of line in asking this...   Aug 3 2007, 02:41 PM
Twystd1   Right on Crusty One........ Mark... To know the C...   Aug 3 2007, 03:22 PM
Steve Thacker   OK I finally got the sucker running right on point...   Aug 6 2007, 12:53 PM
Cap'n Krusty   Yup! Saw it. As always, I'm here to help...   Aug 6 2007, 01:30 PM
Steve Thacker   Thank you to all who came up with ideas to get my ...   Aug 6 2007, 01:49 PM
Junebug   I know this is an old post, But I back Cap'n K...   Jan 23 2016, 09:16 PM
r_towle   RIP cap,n , that was classic, right answer with at...   Jan 23 2016, 09:30 PM
porschetub   RIP cap,n , that was classic, right answer with a...   Jan 23 2016, 11:17 PM
r_towle   RIP cap,n , that was classic, right answer with ...   Jan 24 2016, 04:22 PM
ripper911   Unless the plastic tab that rides the shaft breaks...   Jan 25 2016, 10:39 AM
RenoRoger   Unless the plastic tab that rides the shaft break...   Jan 25 2016, 12:22 PM
ctc911ctc   Just read through this thread. A few observations...   Sep 12 2018, 06:02 PM
worn   Just read through this thread. A few observation...   Sep 12 2018, 07:59 PM
ctc911ctc   :bump: Looking at dwell again to fix my idle cha...   Aug 24 2024, 02:16 PM
914_teener   :bump: Looking at dwell again to fix my idle ch...   Aug 24 2024, 04:54 PM
rfinegan   I can still hear my old high school auto shop teac...   Aug 24 2024, 02:51 PM
- Lo-Fi Version Time is now: 30th May 2026 - 10:12 PM
