| Chuck |
Aug 14 2007, 11:19 PM
What it eventually will look like . . . . ![]() ![]() Group: Members Posts: 355 Joined: 29-March 07 From: Maple Grove, MN Member No.: 7,632 Region Association: Northstar Region |
I was going to use my brother's 220 volt Lincoln for my car restoration (new pans, hell hole kit and long stiffening kit). Unfortunately, due to the limitaitons with the 100 amp panel in my new house, an additional 220 volt tap would be VERY expensive (think new line under the street from the city into my house with all new panel). Sooooo . . .. back to 110 volt options.
I was looking a the Lincoln SP135T. However, for $150 more I can get the 135 Plus with the variable adjustment (versus the click stops with the 135T). Is the variable adjustment worth the extra $150? |
| So.Cal.914 |
Aug 15 2007, 08:38 AM
"...And it has a front trunk too." ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 6,588 Joined: 15-February 04 From: Low Desert, CA./ Hills of N.J. Member No.: 1,658 Region Association: None |
You don't need to add 220, you have it. Tap into two 110 breakers, neutral and
ground. Just make sure that the breakers are for circuits that are light duty and you can turn these items off when you are welding. (IMG:style_emoticons/default/welder.gif) (IMG:style_emoticons/default/smile.gif) |
| Chuck |
Aug 15 2007, 11:00 AM
You don't need to add 220, you have it. Tap into two 110 breakers, neutral and ground. Just make sure that the breakers are for circuits that are light duty and you can turn these items off when you are welding. (IMG:style_emoticons/default/welder.gif) (IMG:style_emoticons/default/smile.gif) That's the problem. The previous owner already has everything in the panel double and triple tapped for when he installed the 220v hot tub and 220v whirlpool in the basement. So the panel is already at max and I need to add 220 for my compressor yet. Could it be made to work? Yes. BUT, I wouldn't necessarily feel comfortable with how it would work. To do it right and reliably would require a new panel. So, update my panel so I can borrow a welder or just buy a 110v unit. Plus, this way the unit is mine versus borrowed and I think a 110 volt unit will suit my needs just fine. |
Chuck Help me buy a welder Aug 14 2007, 11:19 PM
highways
Is the variable adjustment worth the extra ... Aug 15 2007, 03:31 AM
rfuerst911sc I am useing a Hobart 140 and I have welded fender ... Aug 15 2007, 04:35 AM
degreeoff Get the Linc PRO MIG 135...Its a GREAT machine...2... Aug 15 2007, 07:10 AM
iamchappy For less money, the Northern Tools 135 mig will do... Aug 15 2007, 07:29 AM
Vacca Rabite Go with the Lincoln 135. A 220 Welder is too much... Aug 15 2007, 07:31 AM
jasons When I bought my welder (sp135t) I asked an aircra... Aug 15 2007, 07:36 AM
tdgray 'nother vote for the Lincoln... I have abused ... Aug 15 2007, 07:39 AM
jasons
That's the problem. The previous owner alrea... Aug 15 2007, 11:17 AM
Chuck
That's the problem. The previous owner alre... Aug 15 2007, 11:36 AM
jasons
Immediate welding chores are install of an Engman... Aug 15 2007, 11:51 AM
Luke The best deal I could find on my Lincoln was from ... Aug 15 2007, 04:18 PM
alpha434 Get a real autodarkening helmet. One with the bitc... Aug 15 2007, 05:48 PM
So.Cal.914
Why didn't you just say so in the first plac... Aug 15 2007, 07:29 PM
Chuck
Why didn't you just say so in the first pla... Aug 15 2007, 07:34 PM
9146986 If you've got the electric for a 220 then get ... Aug 16 2007, 06:07 PM
Chuck Thanks everyone for your assistance. I ordered a n... Aug 17 2007, 07:46 PM
Jeffs9146
Just run the cord to your dryer plug and use tha... Aug 17 2007, 07:57 PM![]() ![]() |
Lo-Fi Version | Time is now: 2nd April 2026 - 04:06 PM |
