> What do I have in my suspension, and should the swaybars look like that
swl
post Jul 31 2007, 05:04 PM
Ok suspension gurus - help me figure out what I have here. The guy that sold me this car was a flipper so he knew very little about it. He did tell me that it had been driven competitively in SCC events and the rear suspension seems to back that up - hard as hell on the butt! My old car was bone stock and had no sway bars so the only things that I know about suspensions is what I've learned from you guys.
The struts have been painted black but there is an orange label on it.
Can't find any markings on the springs. When you guys talk lbs when talking about spring rates - is that the weight required to compress it a certain distance? 1 inch maybe.
The sway bars are bolt to the underside of the trunk and to the trailing arm. The picture below shows where the bar attaches to the rod from the trailing arm. Should there be a big gap like that? Looks like it is necessary to allow the sway bar to move up and down but the rubber bumpers must really take a beating.
Sorry for the newbie questions but I'm a little out of my league here.
Spoke
post Aug 20 2007, 09:58 PM
Jerry
I have a similar swaybar on my red 71 although the suspension pickups are on the shock bolt. The trunk connection has a plate that goes inside the trunk although it didn't seem to fit when I first put it on.
The holes for the trunk brackets happened to end up on the removable caps on the trunk floor. It didn't seem right but that was the only place it would go.
Not only that, I had to bend the bar so the bushings fit right.
- Lo-Fi Version Time is now: 1st November 2026 - 08:54 AM
