| stephenaki |
Aug 22 2007, 10:17 PM
Can I get this one dad?? ![]() ![]() ![]() Group: Members Posts: 1,191 Joined: 11-August 07 From: Palmetto, FL Member No.: 7,987 Region Association: None |
FNG question again. The 72 914 I just bought has a set of delorto (dellorto?) carbs versus the stock FI set up. I know nothing about these carbs other than that they are very similar to Weber carbs. I am much more familiar with HS2 and HS4 carbs on British cars.
So what is the general thought on carbs versus FI? Should I consider converting it back to FI or just keep and tune the existing carbs? If converting back to FI, how difficult and/or expensive of a project will this be? Enquiring minds want to know. |
| jr91472 |
Aug 22 2007, 10:28 PM
"I'm pacing myself sergeant..." ![]() ![]() ![]() Group: Members Posts: 1,205 Joined: 2-August 04 From: McKinney, TX Member No.: 2,437 |
Depends on what is inside the motor. If you still have the stock cam, then the FI will run best. If you have a carb friendly (aftermarket) cam, then stick with the Dells.
How does it run now? Carbs with a stock cam can work fine, just not optimum. Dells are great (most say they flow better than the Webers). I love mine!! (IMG:style_emoticons/default/beer.gif) FNG question again. The 72 914 I just bought has a set of delorto (dellorto?) carbs versus the stock FI set up. I know nothing about these carbs other than that they are very similar to Weber carbs. I am much more familiar with HS2 and HS4 carbs on British cars. So what is the general thought on carbs versus FI? Should I consider converting it back to FI or just keep and tune the existing carbs? If converting back to FI, how difficult and/or expensive of a project will this be? Enquiring minds want to know. |
| stephenaki |
Aug 22 2007, 10:46 PM
Good question, I have no friggin idea and I don't think the guy that I bought it from has any idea either on what cam she's got in her. I am thinking not since the previous owner (the one prior to the guy now) did work on the engine and put in 2.0 jugs.
I may just let sleeping dogs lie, at least until she shows up and I get a chance to drive her around and see how she performs. |
| Eric_Ciampa |
Aug 22 2007, 11:09 PM
CHAMP914 ![]() ![]() Group: Members Posts: 154 Joined: 3-April 03 From: Placerville, CA Member No.: 511 Region Association: Northern California
I just got a 914 running with a set of dells on mine and I am loving it. Jr is right that the stock setup will run the best with FI but I can't tell any measurable distance. I am sure you will get a good amount of opinons on both sides. This is one of those never ending debates. Just my opinion, but just make sure your system is dialed in and your car is running correctly.
stephenaki Oppinions, carb vs FI Aug 22 2007, 10:17 PM
toon1
FNG question again. The 72 914 I just bought has... Aug 23 2007, 08:49 AM
So.Cal.914 FI sucks, stick with the carbs. :hide:
Its so ... Aug 23 2007, 09:03 AM
jhadler
Actually... Aug 23 2007, 05:44 PM
TROJANMAN
[quote name='So.Cal.914' post='937835' date='Aug ... Aug 23 2007, 05:51 PM
Joe Ricard Tune em and run em as they are.
or
Dump tons of mo... Aug 23 2007, 11:46 AM
stephenaki Interesting banter, don't know much about FI. ... Aug 28 2007, 12:50 PM
Oppinions
yes! :popcorn: Aug 28 2007, 01:03 PM
toon1
Oppinions
yes! :popcorn:
NO! :popco... Aug 28 2007, 01:21 PM![]() ![]() |
Lo-Fi Version | Time is now: 2nd April 2026 - 07:32 PM |
