914 Rear Fog Lamp Installation with details & Photo's, Only winning cars have them, BLing, Bling. |
TJB/914 |
Jun 30 2007, 03:50 PM
Mid-Engn. Group: Members Posts: 4,333 Joined: 24-February 03 From: Plymouth & Petoskey, MI Member No.: 346 Region Association: Upper MidWest |
Hi Guys,
I just finished drilling (2) 6mm holes & (1) 3mm hole in by trunk to mount my "Rear Fog Light" factory accessory. I like it, makes my car different from all the others. (IMG:style_emoticons/default/pray.gif) Here's a few pictures to show details of the U.S.A. issue rear fog lamp I installed. I got a Euro fog lamp assembly from Gustl (thanks Gustl-aka-Wolfgang) & put everything together using the satin black U.S. housing with the Euro lens because I thought it looked better. One of the brackets to mount is still available from Porsche, but the exterior bracket is NLA. The exterior bracket I got from Gustl was a surprise, it's made of stainless steel. I'll post a number of photo's in a few days showing lots of details & differences. (IMG:style_emoticons/default/popcorn[1].gif) Hope you guys enjoy. Tom BTW Pat: I measured a lot before drilling the holes. Attached thumbnail(s) Attached image(s) |
Eric_Shea |
Aug 22 2007, 07:46 PM
PMB Performance Group: Admin Posts: 19,278 Joined: 3-September 03 From: Salt Lake City, UT Member No.: 1,110 Region Association: Rocky Mountains |
Wow! Way cool. Am I reading this right? 233" (IMG:style_emoticons/default/ohmy.gif)
Where does this thing route? Thanks Mike. I hope you and Jeff can hook up. Seems like a simple one but, I don't harnesses, Jeff does. (IMG:style_emoticons/default/biggrin.gif) (IMG:style_emoticons/default/smilie_pokal.gif) |
914Mike |
Aug 25 2007, 11:31 AM
Member Group: Members Posts: 330 Joined: 27-January 03 From: San Jose, CA Member No.: 198 |
Wow! Way cool. Am I reading this right? 233" (IMG:style_emoticons/default/ohmy.gif) Where does this thing route? Thanks Mike. I hope you and Jeff can hook up. Seems like a simple one but, I don't harnesses, Jeff does. (IMG:style_emoticons/default/biggrin.gif) (IMG:style_emoticons/default/smilie_pokal.gif) (IMG:style_emoticons/default/aktion035.gif) Yup, 233" total for the white/green wire. It follows the rear harness around the trunk, over the wheel arch and down into the left "pit" where the ground is tied under the relay board. From there it joins the main harness across the firewall, down through the rubber tube and into the tunnel. So I'm guessing there is enough length to follow the wires along the top of the tunnel and up into the dash somehow. It must connect to the fuse block or the foglight switch, so it's probably just the right length for either of those. Luckily, I did not want to cut the nice insulated connector off the front end when I wired it to a pushbutton on my console, been coiled up in there for quite some time... (IMG:style_emoticons/default/sawzall-smiley.gif) (IMG:style_emoticons/default/welder.gif) With all the mods I'm doing now, I'm sure I don't need it, so Hopefully Jeff will be able to find the proper wire color and sleeving to make you all some nice repros... (IMG:style_emoticons/default/thumb3d.gif) |
Lo-Fi Version | Time is now: 1st June 2024 - 06:55 AM |
