Engine bay seals-door seals |
Mikey914 |
Aug 3 2007, 11:21 PM
The rubber man Group: Members Posts: 12,671 Joined: 27-December 04 From: Hillsboro, OR Member No.: 3,348 Region Association: None |
Figured I'd add to the other seal thread to keep everything together. Just cut the die for the other 3 engine seals and have sample material back. I've checked it out and it fits as good as the original. I'm selling a strip that is cut in the field to fit. You would need less than 100" to do all 3, I'm sending at least 102" to allow for any variation.
You'll have to scroll down to the bottom, but picture is attached. This will do all 3 seals for $72+shipping (seals available after Oct 16th) It's cheapest to send Priority mail flat rate for $9.20 domestic. ___________________________________________________________________ Ok, finally got the door seal materials back and checked for fit. These fit nicely. Not too large for the opening, but solid fit to the door. These are not oem. They are reproduction. They ARE NOT a generic seal that is just a bulb on the side of a trim channel like you see advertised on some ebay listings. $32 for a set left and right. Compare to 914-531-821-10 & 914-531-822-10 15 _________________________________________________ 914-504-117-10 Reproduction Engine compartment seal above transmission $28 28 __________________________________________________________________ Paypal or check ok Attached image(s) |
Mikey914 |
Aug 26 2007, 09:36 PM
More to come
Lo-Fi Version | Time is now: 23rd May 2024 - 05:21 AM |
