Pin your engine bay lid for <$3, Another Screaming Monkey Research labs/EvilWerks innovation |
Dr Evil |
Sep 3 2007, 01:43 PM
Send me your transmission! Group: Members Posts: 23,002 Joined: 21-November 03 From: Loveland, OH 45140 Member No.: 1,372 Region Association: MidAtlantic Region |
Since I have CIS on my engine it takes up a bit of room. This created a need to remove the engine bay latch and all of its related hardware, but this left the hood flopping if I ever hit bumps. I wanted to put pins in, but didnt know how....until I was inspired last night!
List of materials: - the rubber stoppers that you already have that your lid rests on - 2x 1/4" x 3" (its good to go longer so you can cut off the excess) stainless/zinc bolts ~ $.18ea - 2x flat 1/4" washers, Stainless/zinc ~ $.10ea - 2x 1/16" pins, ~$1.20 - Drill bits, drill, cut off wheel 1) Take the rubber nubs off. They are threaded and unscrew. 2) Drill a hole that is smaller than 1/4 inch buy 2 sizes down the center of the nubs (I forget what I used, I just grabbed the bit two sizes down) 3) Cut heads off of bolts and place the bolt shaft into the holes you drilled. |
Dr Evil |
Sep 3 2007, 04:10 PM
The lid has the lip removed in the center to clear the CIS air boot so it is easy to open. I may attach the pins with fishing leaders and JB weld the washers in place. We will see, I want stand for tacky.
Lo-Fi Version | Time is now: 31st May 2024 - 10:37 PM |
