Compression Ratio, Too High...Too Low ??? |
2-OH! |
Sep 6 2007, 05:44 PM
Senior Member Group: Members Posts: 552 Joined: 17-October 03 From: Santa Clarita, Kalifornication Member No.: 1,253 |
Ok folks,
We just finished rebuilding the motor...94mm pistons and cylinders to match...71mm stroke...but old 1.7 case...CC'd the heads and come up with 44 cc's per cylinder... Do the calculations and we come out with 1971 cc's...Great !!! But, The problem is the compression ratio is now 10.64 to 1... The question of the day: Should I take the cylinders and heads back off and shim them to get a little relief...Probably not going to get much...Might knock it down to 10 or 9.75 (if I'm lucky)... DO NOT want this thing to clatter and diesel on me when I get it back together... OK, let me have it...What are your thoughts ??? 2-OH! |
2-OH! |
Sep 6 2007, 10:14 PM
Thanks Clayton...
The way I measured it was with the cylinder hand tight using a spacer and nut to hold it in place... Calipers, using the depth gauge end...71.77mm, BDC... .55 TDC...Leaving a balance of 71.22mm... Actually, Looking at my notes, I'm not sure about that...That could be the problem in the math... In short, is there anyway to check the CR without disassembling at least one head ??? |
Lo-Fi Version | Time is now: 6th June 2024 - 08:56 AM |
