Compression Ratio, Too High...Too Low ??? |
2-OH! |
Sep 6 2007, 05:44 PM
Senior Member Group: Members Posts: 552 Joined: 17-October 03 From: Santa Clarita, Kalifornication Member No.: 1,253 |
Ok folks,
We just finished rebuilding the motor...94mm pistons and cylinders to match...71mm stroke...but old 1.7 case...CC'd the heads and come up with 44 cc's per cylinder... Do the calculations and we come out with 1971 cc's...Great !!! But, The problem is the compression ratio is now 10.64 to 1... The question of the day: Should I take the cylinders and heads back off and shim them to get a little relief...Probably not going to get much...Might knock it down to 10 or 9.75 (if I'm lucky)... DO NOT want this thing to clatter and diesel on me when I get it back together... OK, let me have it...What are your thoughts ??? 2-OH! |
Brett W |
Sep 7 2007, 11:51 AM
Advanced Member Group: Members Posts: 2,856 Joined: 17-September 03 From: huntsville, al Member No.: 1,169 Region Association: None |
Chamber volume can only be calculated by measuring the fluid volume capacity of the chamber. You can't calculate it by measuring the chamber dimensionally. So double check your chamber volume and deck height.
Lo-Fi Version | Time is now: 13th June 2024 - 04:38 AM |
