> Suspension Tuning Setup Advice Needed..., went from a swinger to a plow...
cha914
post Dec 8 2003, 02:02 PM
MUSR 8 - 5lug conversion done wed - drive 500miles thrus
Ok, did the first autox with the new suspension on sunday, and I wasn't overly impressed with the results, but since I changed almost everything, I cant realy expect to have it right the first time.
So here goes, the car had very sluggish turn-in responce, and wanted to plow through every corner. I really couldn't even get it to rotate under trail braking. Here is the setup:
Koni Yellows all around
Poly bushings all around
Fully adj rear perches w/175lb springs
22mm solid torsion bars
22mm weltmeister front bar set full soft
Ride height = 4.75 up front and ~5.25 rear (measured to the donuts)
Camber = -1.5 up front -2 rear
Toe = 1/16th toe OUT up front and 1/16th toe IN rear
With the Koni's set to full hard the car seemed to improve a little, but not much. Also, the course was on a fairly slick parking lot, and I am running 2year old pirelli tires (205/50/15s with plenty of tread, just hard).
Finally, I want this car setup mostly for track driving, so I know autox performance is going to suffer some, but it seemed pretty poor overall yesterday (it was definately more fun with the ass up in the air sliding everywhere (IMG:style_emoticons/default/tongue.gif) now I want it to be fast)
Any suggestions on where to go from here, or what to try in the future (I know I need better tires).
Tony (IMG:style_emoticons/default/smash.gif)
machina
post Dec 8 2003, 02:41 PM
I agree with chris about more camber up front but I wouldn't change anymore hardware until you run the car on the track.
Auto-X setup is very different than roadracing setup. Most cars tend to plow at lower speeds.
Your setup looks pretty good as a baseline.
dr
cha914   Suspension Tuning Setup Advice Needed...   Dec 8 2003, 02:02 PM
ChrisReale   You might need heaver rear springs. Also, many pe...   Dec 8 2003, 02:18 PM
synthesisdv   I agree with chris about more camber up front but ...   Dec 8 2003, 02:41 PM
john rogers   I'd say it is the tires and a pretty good lack...   Dec 8 2003, 02:46 PM
J P Stein   I'm with stupid...er, Chris. Better tires will...   Dec 8 2003, 03:21 PM
cha914   *sigh* yeah, I need tires, but I have already bou...   Dec 8 2003, 04:24 PM
MJHanna     Dec 8 2003, 05:37 PM
cha914   Here are a few shots of the car in action...somebo...   Dec 8 2003, 09:31 PM
cha914   lifting the inside front?   Dec 8 2003, 09:32 PM
cha914   turn damit...turn ...   Dec 8 2003, 09:33 PM
cha914   I guess I will leave it as is for now, and get som...   Dec 8 2003, 09:38 PM
DuckRyder   Does it have a rear bar? For Autocross I think it...   Dec 8 2003, 09:41 PM
cha914   Nope, no rear bar...I think I have actually heard ...   Dec 8 2003, 10:49 PM
ChrisReale   :barf: .....you need more rear spring.......... :b...   Dec 8 2003, 11:21 PM
SirAndy   front is loose, tighten the back back is loose, ti...   Dec 8 2003, 11:40 PM
J P Stein   Heavier rear springs keeps the inside front wheel ...   Dec 8 2003, 11:53 PM
SirAndy   ...   Dec 8 2003, 11:58 PM
fiid   I was also told that a rear bar was good for getti...   Dec 9 2003, 12:39 AM
Brett W   With 22mm bars up front you need to be running at ...   Dec 9 2003, 01:11 AM
J P Stein   Come to think of it......... I encourage you all n...   Dec 9 2003, 01:57 AM
DuckRyder   The disclaimer is that this is non-914 specific ex...   Dec 9 2003, 06:31 AM
MJHanna   I run 200lbs springs on the rear with 21mm bars. D...   Dec 9 2003, 07:00 AM
Eric_Shea   So, as the concensous shows... you either went too...   Dec 9 2003, 08:03 AM
cha914   Thanks for all the replys guys! To answer a f...   Dec 9 2003, 08:54 AM
DuckRyder   To add insult to injury, you really need two sets ...   Dec 9 2003, 11:39 AM
Brad Roberts   The guy has Empi 8 spokes. This means the largest ...   Dec 10 2003, 01:48 AM
J P Stein
  Dec 10 2003, 12:34 PM
Brad Roberts   Sorry, straight off the plane. Should'nt have ...   Dec 10 2003, 12:38 PM
Eric_Shea   Awwwwwwwwe... :wub: How can ya stay mad at him?...   Dec 10 2003, 12:45 PM
Brad Roberts   I thought I was "done" being pissed off at life. S...   Dec 10 2003, 12:50 PM
maf914   Hey, nobody suggested a set of Mueller's beari...   Dec 10 2003, 01:00 PM
Eric_Shea   Mueller's bearings aren't worth SHIT until...   Dec 10 2003, 01:28 PM
Brad Roberts   Yeah.. the welcome wagon has runeth over. B   Dec 10 2003, 01:29 PM
cha914   Ouch...well, actually I was able to get 205 new pi...   Dec 10 2003, 01:41 PM
Eric_Shea   Tony, Tony, Tony... See the shit storm you caused...   Dec 10 2003, 01:50 PM
fiid
- Lo-Fi Version Time is now: 15th July 2025 - 07:45 PM
