Compression Ratio, Too High...Too Low ??? |
2-OH! |
Sep 6 2007, 05:44 PM
Senior Member Group: Members Posts: 552 Joined: 17-October 03 From: Santa Clarita, Kalifornication Member No.: 1,253 |
Ok folks,
We just finished rebuilding the motor...94mm pistons and cylinders to match...71mm stroke...but old 1.7 case...CC'd the heads and come up with 44 cc's per cylinder... Do the calculations and we come out with 1971 cc's...Great !!! But, The problem is the compression ratio is now 10.64 to 1... The question of the day: Should I take the cylinders and heads back off and shim them to get a little relief...Probably not going to get much...Might knock it down to 10 or 9.75 (if I'm lucky)... DO NOT want this thing to clatter and diesel on me when I get it back together... OK, let me have it...What are your thoughts ??? 2-OH! |
Brett W |
Sep 10 2007, 11:16 PM
Advanced Member Group: Members Posts: 2,856 Joined: 17-September 03 From: huntsville, al Member No.: 1,169 Region Association: None |
Just put the heads on and run them. Don't worry about it. In the meantime let someone work the other set of heads up. Then decide if the compression is too high. The higher compression will give you better drivability.
The flywheel is kinda scary. Whats wrong with the crankshaft? I don't see anything other than a counter-weighted crank. Toss the D-jet and put some decent injection on there. Then you won't have to wonder if the stock (Crappy) injection will work. |
Lo-Fi Version | Time is now: 1st June 2024 - 01:26 AM |
