cha914 |
MUSR 8 - 5lug conversion done wed - drive 500miles thrus ![]() ![]() ![]() Group: Members Posts: 739 Joined: 31-December 02 From: Austin, TX Member No.: 63 ![]() |
Ok, did the first autox with the new suspension on sunday, and I wasn't overly impressed with the results, but since I changed almost everything, I cant realy expect to have it right the first time.
So here goes, the car had very sluggish turn-in responce, and wanted to plow through every corner. I really couldn't even get it to rotate under trail braking. Here is the setup: Koni Yellows all around Poly bushings all around Fully adj rear perches w/175lb springs 22mm solid torsion bars 22mm weltmeister front bar set full soft Ride height = 4.75 up front and ~5.25 rear (measured to the donuts) Camber = -1.5 up front -2 rear Toe = 1/16th toe OUT up front and 1/16th toe IN rear With the Koni's set to full hard the car seemed to improve a little, but not much. Also, the course was on a fairly slick parking lot, and I am running 2year old pirelli tires (205/50/15s with plenty of tread, just hard). Finally, I want this car setup mostly for track driving, so I know autox performance is going to suffer some, but it seemed pretty poor overall yesterday (it was definately more fun with the ass up in the air sliding everywhere (IMG:style_emoticons/default/tongue.gif) now I want it to be fast) Any suggestions on where to go from here, or what to try in the future (I know I need better tires). Tony (IMG:style_emoticons/default/smash.gif) |
J P Stein |
Irrelevant old fart ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 8,797 Joined: 30-December 02 From: Vancouver, WA Member No.: 45 Region Association: None ![]() |
I'm with stupid...er, Chris.
Better tires will just make it plow at a higher speed (IMG:style_emoticons/default/laugh.gif) I'm running 200lb (non progressive) rears & 21 mm T bars. It still pushes in the tight stuff. I have a fair amount AR softening adjustment left and will do so for next season. AFIK, 200 lb springs are as stiff as I can go with stock dia 914 (the big OD) springs. For my set-up (AX being the main focus), 225 or 250s would be better....*I think*. The present set-up seems very nice for the big track.....dead neutral, but I ain't worth spit at that stuff. Negative camber is good for tires that *require* it. Rspec Kumhos & Hoosiers fall into that catagory. |
Lo-Fi Version | Time is now: 15th July 2025 - 07:46 PM |
