Compression Ratio, Too High...Too Low ??? |
2-OH! |
Sep 6 2007, 05:44 PM
Senior Member Group: Members Posts: 552 Joined: 17-October 03 From: Santa Clarita, Kalifornication Member No.: 1,253 |
Ok folks,
We just finished rebuilding the motor...94mm pistons and cylinders to match...71mm stroke...but old 1.7 case...CC'd the heads and come up with 44 cc's per cylinder... Do the calculations and we come out with 1971 cc's...Great !!! But, The problem is the compression ratio is now 10.64 to 1... The question of the day: Should I take the cylinders and heads back off and shim them to get a little relief...Probably not going to get much...Might knock it down to 10 or 9.75 (if I'm lucky)... DO NOT want this thing to clatter and diesel on me when I get it back together... OK, let me have it...What are your thoughts ??? 2-OH! |
Jake Raby |
Sep 11 2007, 10:09 AM
Engine Surgeon Group: Members Posts: 9,394 Joined: 31-August 03 From: Lost Member No.: 1,095 Region Association: South East States |
It'll take 8-12cc of piston dish to get the CR back in check, so just use a VW Bus 029 piston thathas a 12cc dish from the factory to get the CR closer in check..
Doing the dish mod to a stock 914 spec piston will more than likely compromise the piston's integrity- thats a lot of material from a piston that wasn't designed for a dish. |
Lo-Fi Version | Time is now: 6th June 2024 - 12:56 PM |
