cha914 |
MUSR 8 - 5lug conversion done wed - drive 500miles thrus ![]() ![]() ![]() Group: Members Posts: 739 Joined: 31-December 02 From: Austin, TX Member No.: 63 ![]() |
Ok, did the first autox with the new suspension on sunday, and I wasn't overly impressed with the results, but since I changed almost everything, I cant realy expect to have it right the first time.
So here goes, the car had very sluggish turn-in responce, and wanted to plow through every corner. I really couldn't even get it to rotate under trail braking. Here is the setup: Koni Yellows all around Poly bushings all around Fully adj rear perches w/175lb springs 22mm solid torsion bars 22mm weltmeister front bar set full soft Ride height = 4.75 up front and ~5.25 rear (measured to the donuts) Camber = -1.5 up front -2 rear Toe = 1/16th toe OUT up front and 1/16th toe IN rear With the Koni's set to full hard the car seemed to improve a little, but not much. Also, the course was on a fairly slick parking lot, and I am running 2year old pirelli tires (205/50/15s with plenty of tread, just hard). Finally, I want this car setup mostly for track driving, so I know autox performance is going to suffer some, but it seemed pretty poor overall yesterday (it was definately more fun with the ass up in the air sliding everywhere (IMG:style_emoticons/default/tongue.gif) now I want it to be fast) Any suggestions on where to go from here, or what to try in the future (I know I need better tires). Tony (IMG:style_emoticons/default/smash.gif) |
cha914 |
I guess I will leave it as is for now, and get some seat time on the track (and also try and get on some scales) ... but I have a couple quick questions:
i could just as easily go down to 19mm torsions, rather than put heavier springs on the rear...correct...similar result? And two, many of you have said I am now under sprung in the rear, and I have seen several racers run very heavy springs in the rear, any particular one reason for this type of setup? or you guys just like really stiff cars? Thanks again, Tony (IMG:style_emoticons/default/MDB2.gif) |
Lo-Fi Version | Time is now: 15th July 2025 - 07:29 PM |
