Allan |
Teenerless Weenie ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 8,373 Joined: 5-July 04 From: Western Mesopotamia Member No.: 2,304 Region Association: Southern California ![]() |
I think I may have inadvertantly flooded my car yesterday after installing a new fuel pump.
I've let it set overnight without tinkering with it and am hoping it will start today. Is 16 hours enough time for the fuel to dissipate )sp? If it is flooded, what's the best way to get it started? /6 with carbs btw.... |
Brando |
BUY MY SPARE KIDNEY!!! ![]() ![]() ![]() ![]() Group: Members Posts: 3,935 Joined: 29-August 04 From: Santa Ana, CA Member No.: 2,648 Region Association: Southern California ![]() |
And, if you let it sit overnight, all that fuel will run past the pistons into the sump. Not good. Fuel doesn't evaporate from a cylinder when the valves are closed. Throttle wide open, crank it over, remove center plug wire. Put a battery charger on it. You may see some fuel come out the muffler, might not. After about 30 seconds hook up your center plug wire again. Crank it over throttle open. I may suggest an oil change soon... |
Lo-Fi Version | Time is now: 8th July 2025 - 12:53 PM |
