Headlight Operations, Passenger side won't open |
HalM |
Sep 16 2007, 03:21 PM
Green Skull 003 Group: Members Posts: 127 Joined: 19-January 05 From: The 'Burg Member No.: 3,472 Region Association: None |
I got the 914 back from my wrench 2 weeks ago and have been driving it in daylight only. This morning I leave earlier than normal and decide to turn on the headlights. The driver's side opens normally but the passenger side stays closed. I didn't really need them so I turned them off and continued my trip.
I got home about an hour ago and started troubleshooting as best I could. I checked all fuses and relays, including swapping in a known good relay. No joy. The lights worked fine when it went to the shop. I know this because I had to replace a fuse I had kicked out by mistake one afternoon. Any suggestions on what to do next? If I get in a bind, is there a way to manually open the light? Any and all help is much appreciated. |
stateofidleness |
Sep 16 2007, 04:00 PM
Senior Member Group: Members Posts: 810 Joined: 1-September 07 From: Canyon Lake, Texas! Member No.: 8,065 Region Association: None |
happened to me the other day, all i did was check the physical wires going into the connector and verified they were all nice in tight inside the connector. you might even try unplugging and plugging back in the connector. it worked for me
Lo-Fi Version | Time is now: 10th June 2024 - 11:03 AM |
