> Suspension Tuning Setup Advice Needed..., went from a swinger to a plow...
cha914
post Dec 8 2003, 02:02 PM
MUSR 8 - 5lug conversion done wed - drive 500miles thrus
Ok, did the first autox with the new suspension on sunday, and I wasn't overly impressed with the results, but since I changed almost everything, I cant realy expect to have it right the first time.
So here goes, the car had very sluggish turn-in responce, and wanted to plow through every corner. I really couldn't even get it to rotate under trail braking. Here is the setup:
Koni Yellows all around
Poly bushings all around
Fully adj rear perches w/175lb springs
22mm solid torsion bars
22mm weltmeister front bar set full soft
Ride height = 4.75 up front and ~5.25 rear (measured to the donuts)
Camber = -1.5 up front -2 rear
Toe = 1/16th toe OUT up front and 1/16th toe IN rear
With the Koni's set to full hard the car seemed to improve a little, but not much. Also, the course was on a fairly slick parking lot, and I am running 2year old pirelli tires (205/50/15s with plenty of tread, just hard).
Finally, I want this car setup mostly for track driving, so I know autox performance is going to suffer some, but it seemed pretty poor overall yesterday (it was definately more fun with the ass up in the air sliding everywhere (IMG:style_emoticons/default/tongue.gif) now I want it to be fast)
Any suggestions on where to go from here, or what to try in the future (I know I need better tires).
Tony (IMG:style_emoticons/default/smash.gif)
Brett W
post Dec 9 2003, 01:11 AM
With 22mm bars up front you need to be running at least 200s and maybe even 250s in the rear. I was running my four cylinder car with 180 rears on Carreras, no rear bar, stock tbars up front and a 23mm sway bar set at half way. You could run a rear bar and for go the heavy springs, this could lead to lifting the inside rear tire though on a tight course.
What tire pressure were you running? Run as much caster as you can get, set the rear to zero toe and run as much camber as you can get. Run your fron tire pressure lower in the front than in the rear. Also set the front shocks to full soft and see what happens. Are you running with a full tank of gas? Lose the passenger your car will handle very differently with a passenger. Make sure you can grease the poly bushings and do so before each event. Are you running a limited slip?
cha914   Suspension Tuning Setup Advice Needed...   Dec 8 2003, 02:02 PM
ChrisReale   You might need heaver rear springs. Also, many pe...   Dec 8 2003, 02:18 PM
synthesisdv   I agree with chris about more camber up front but ...   Dec 8 2003, 02:41 PM
john rogers   I'd say it is the tires and a pretty good lack...   Dec 8 2003, 02:46 PM
J P Stein   I'm with stupid...er, Chris. Better tires will...   Dec 8 2003, 03:21 PM
cha914   *sigh* yeah, I need tires, but I have already bou...   Dec 8 2003, 04:24 PM
MJHanna     Dec 8 2003, 05:37 PM
cha914   Here are a few shots of the car in action...somebo...   Dec 8 2003, 09:31 PM
cha914   lifting the inside front?   Dec 8 2003, 09:32 PM
cha914   turn damit...turn ...   Dec 8 2003, 09:33 PM
cha914   I guess I will leave it as is for now, and get som...   Dec 8 2003, 09:38 PM
DuckRyder   Does it have a rear bar? For Autocross I think it...   Dec 8 2003, 09:41 PM
cha914   Nope, no rear bar...I think I have actually heard ...   Dec 8 2003, 10:49 PM
ChrisReale   :barf: .....you need more rear spring.......... :b...   Dec 8 2003, 11:21 PM
SirAndy   front is loose, tighten the back back is loose, ti...   Dec 8 2003, 11:40 PM
J P Stein   Heavier rear springs keeps the inside front wheel ...   Dec 8 2003, 11:53 PM
SirAndy   ...   Dec 8 2003, 11:58 PM
fiid   I was also told that a rear bar was good for getti...   Dec 9 2003, 12:39 AM
Brett W   With 22mm bars up front you need to be running at ...   Dec 9 2003, 01:11 AM
J P Stein   Come to think of it......... I encourage you all n...   Dec 9 2003, 01:57 AM
DuckRyder   The disclaimer is that this is non-914 specific ex...   Dec 9 2003, 06:31 AM
MJHanna   I run 200lbs springs on the rear with 21mm bars. D...   Dec 9 2003, 07:00 AM
Eric_Shea   So, as the concensous shows... you either went too...   Dec 9 2003, 08:03 AM
cha914   Thanks for all the replys guys! To answer a f...   Dec 9 2003, 08:54 AM
DuckRyder   To add insult to injury, you really need two sets ...   Dec 9 2003, 11:39 AM
Brad Roberts   The guy has Empi 8 spokes. This means the largest ...   Dec 10 2003, 01:48 AM
J P Stein
  Dec 10 2003, 12:34 PM
Brad Roberts   Sorry, straight off the plane. Should'nt have ...   Dec 10 2003, 12:38 PM
Eric_Shea   Awwwwwwwwe... :wub: How can ya stay mad at him?...   Dec 10 2003, 12:45 PM
Brad Roberts   I thought I was "done" being pissed off at life. S...   Dec 10 2003, 12:50 PM
maf914   Hey, nobody suggested a set of Mueller's beari...   Dec 10 2003, 01:00 PM
Eric_Shea   Mueller's bearings aren't worth SHIT until...   Dec 10 2003, 01:28 PM
Brad Roberts   Yeah.. the welcome wagon has runeth over. B   Dec 10 2003, 01:29 PM
cha914   Ouch...well, actually I was able to get 205 new pi...   Dec 10 2003, 01:41 PM
Eric_Shea   Tony, Tony, Tony... See the shit storm you caused...   Dec 10 2003, 01:50 PM
fiid
- Lo-Fi Version Time is now: 15th July 2025 - 07:50 PM
