Headlight Operations, Passenger side won't open |
HalM |
Sep 16 2007, 03:21 PM
Green Skull 003 Group: Members Posts: 127 Joined: 19-January 05 From: The 'Burg Member No.: 3,472 Region Association: None |
I got the 914 back from my wrench 2 weeks ago and have been driving it in daylight only. This morning I leave earlier than normal and decide to turn on the headlights. The driver's side opens normally but the passenger side stays closed. I didn't really need them so I turned them off and continued my trip.
I got home about an hour ago and started troubleshooting as best I could. I checked all fuses and relays, including swapping in a known good relay. No joy. The lights worked fine when it went to the shop. I know this because I had to replace a fuse I had kicked out by mistake one afternoon. Any suggestions on what to do next? If I get in a bind, is there a way to manually open the light? Any and all help is much appreciated. |
HalM |
Sep 16 2007, 04:49 PM
Thanks guys. Question about the relay: Is there a separate relay for each headlight?
I just tried checking the connector but that too failed to activate the headlight. The good news is that the knob does open it and the headlight is on. Has the headlight motor been known to die with any frequency? |
Lo-Fi Version | Time is now: 10th June 2024 - 04:18 AM |
