VaccaRabite |
En Garde! ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Admin Posts: 13,757 Joined: 15-December 03 From: Dallastown, PA Member No.: 1,435 Region Association: MidAtlantic Region ![]() ![]() |
So, while waiting for paint to dry, I figured I'd start rebuilding my pedal cluster. It needs it.
I have most of the stuff off, but for the life of me I can't figure out how to: a ) remove the springs to the brake and clutch pedal return b ) remove the actual brake and clutch pedals How is it done? Is there a special tool used that I don't have? I tried beer, but that not helping as much as it usually does. (IMG:style_emoticons/default/beer3.gif) Zach |
Eric_Shea |
PMB Performance ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Admin Posts: 19,304 Joined: 3-September 03 From: Salt Lake City, UT Member No.: 1,110 Region Association: Rocky Mountains ![]() ![]() |
Another thing on roll pins. They are an absolute "breeze" to get out if you have air tools.
Put a pointed bit in the air hammer and get it started. Finish the job with a 1/8" drift. This has worked "every" time without fail. The pin will be out in less than 30 seconds. More food for thought: The screwdriver under the clutch arm (as mentioned in the PP article) "never" works in this situation. You will only bend and mangle your pedal stop support (the one that is clearly bent and mangled in photo #11) Not panning on the article, it's very complete. This section is just wrong IMO. |
Lo-Fi Version | Time is now: 11th July 2025 - 08:11 AM |
