| Chuck |
Sep 18 2007, 07:22 PM
What it eventually will look like . . . . ![]() ![]() Group: Members Posts: 355 Joined: 29-March 07 From: Maple Grove, MN Member No.: 7,632 Region Association: Northstar Region |
I'm curious if anyone here has ever put some sort of electric heater into their 914. 914-6 heat exchangers, or equivalent, are $1500+. A header can be had for $400 and increases performance. (IMG:style_emoticons/default/biggrin.gif) I can live without heat per se, but I will really need a defog option in my car for rainy days. Anyone rigged something up? Care to share?
| Rand |
Sep 19 2007, 03:11 PM
Cross Member ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 7,414 Joined: 8-February 05 From: OR Member No.: 3,573 Region Association: None |
Forget electric. One that would actually work takes more power than you can supply in a car.
They make little units you can throw on your dash that almost work for a defroster (like this one) but they will make your stock wiring dangerously hot in 15 minutes and don't do much. Making real heat from car electricity is out of the question. The gas heaters work (Eberspacher, Webasto, etc). If they are installed and maintained properly, they are safe and reliable. There are several threads around here about them, so a search will turn up the info. If you want a ridiculously simple solution for occasional heat, look into a Coleman golf cart heater. Drop it in a cupholder, or make a simple dash mount that lets you rotate it to aim at you or the windshield. (I know, not an elegant solution. But I am going to headers, rarely need heat, and like to keep my 914 as simple and light as possible, so it works for me.) (IMG:http://www.coleman.com/coleman/images/products/5036-850_200.jpg) |
| racunniff |
Sep 19 2007, 10:10 PM
volt914 ![]() ![]() Group: Members Posts: 172 Joined: 21-August 06 From: Fort Collins, CO Member No.: 6,705 Region Association: Rocky Mountains |
Forget electric. One that would actually work takes more power than you can supply in a car. I'm putting an electric heater in mine: http://www.canev.com/KitsComp/Components/Heater.html But I have 1200 pounds of batteries to draw from (IMG:style_emoticons/default/biggrin.gif) http://volt914.blogspot.com/2007/07/144v-p...s-charging.html |
Chuck Heat for Heat Exchangerless Cars? Sep 18 2007, 07:22 PM
ConeDodger
I'm curious if anyone here has ever put some ... Sep 18 2007, 07:27 PM
Chuck
In Minnesota you would need at the least a defros... Sep 18 2007, 09:15 PM
Blood red 914-6gt A really big Jacket :D I just use the rain-x no fo... Sep 18 2007, 07:29 PM
swl Chuck. My daily driver is a smart car - super eff... Sep 18 2007, 07:35 PM
Blood red 914-6gt
There was a gas heater available on the original ... Sep 18 2007, 08:05 PM
jd74914 I thought they were actually pretty safe? Anyways,... Sep 18 2007, 08:08 PM
swl lol - searching for heater on the smart board brin... Sep 18 2007, 08:13 PM
Grelber Put two 12 volt hair blow dryers in the front trun... Sep 18 2007, 08:42 PM
Chuck
Put two 12 volt hair blow dryers in the front tru... Sep 18 2007, 09:55 PM
alpha434 Eberspacher.
Check both the Samba and your FLVWPs... Sep 18 2007, 08:48 PM
Wannabe 914-6 owner Seems like JC Whitney used to offer a gas heater s... Sep 18 2007, 09:03 PM
Dr Evil The Corvair also had a reliable gas heater that ma... Sep 18 2007, 09:03 PM
sww914 Gas heaters are all over thesamba for $100.00... Sep 18 2007, 09:06 PM
swl forget the smart heater. Diesel fuel (duh!), ... Sep 18 2007, 09:24 PM
rktmn247 I am from MN. and when visiting my family one win... Sep 18 2007, 11:24 PM
Vacca Rabite
I am from MN. and when visiting my family one wi... Sep 19 2007, 07:35 AM
Chuck
I am from MN. and when visiting my family one wi... Sep 19 2007, 12:27 PM
rktmn247
I am from MN. and when visiting my family one w... Sep 19 2007, 01:43 PM
John I know that they make small square space heaters t... Sep 19 2007, 12:42 PM
davep No electric heater will work effectively, the alte... Sep 19 2007, 01:09 PM
stephenaki
No electric heater will work effectively, the alt... Sep 20 2007, 02:15 PM
alpha434
Forget electric. One that would actually work tak... Sep 19 2007, 10:31 PM
Rand
Where does the carbon monoxide go?
Not all heat... Sep 19 2007, 11:35 PM
9146986 I got a very near NOS Webasto, originally for a 35... Sep 19 2007, 10:54 PM
boxstr How about seat heaters?? CAMP 914 sells them.
CCLI... Sep 19 2007, 10:57 PM
Chuck
CCL... Sep 19 2007, 11:20 PM
Zundfolge
I need to keep the windshield defogged when rainy... Sep 20 2007, 09:43 AM
Chuck
I need to keep the windshield defogged when rain... Sep 20 2007, 03:07 PM
alpha434 I was serious... Where does the exhaust go? I migh... Sep 19 2007, 11:35 PM
Bartlett 914
I was serious... Where does the exhaust go? I mig... Sep 20 2007, 08:12 AM
Rand
I was serious... Where does the exhaust go? I mig... Sep 20 2007, 02:21 PM
EyeTrip I don't know how much room you have with a 6, ... Sep 20 2007, 10:09 AM
Vacca Rabite If you are just concerned about windshield fogging... Sep 20 2007, 10:17 AM
marks914 My setup would probably work, it will be available... Sep 20 2007, 10:40 AM
Vacca Rabite
My setup would probably work, it will be availabl... Sep 20 2007, 10:48 AM
marks914
My setup would probably work, it will be availab... Sep 21 2007, 01:41 AM
tdgray Why reinvent the wheel :confused:
Just use the VW... Sep 20 2007, 02:30 PM
GeorgeRud I bought an Eberspacher gasoline fired heater off ... Sep 20 2007, 02:38 PM
Brian Mifsud
I'm curious if anyone here has ever put some ... Sep 21 2007, 11:37 AM
Chuck I believe though, that after adding up all the cos... Sep 21 2007, 12:38 PM
Eddie914 I installed one of these:
http://www.autobarn.net... Sep 21 2007, 08:26 PM![]() ![]() |
Lo-Fi Version | Time is now: 2nd April 2026 - 10:20 AM |
