Heat for Heat Exchangerless Cars? |
Chuck |
Sep 18 2007, 07:22 PM
What it eventually will look like . . . . Group: Members Posts: 355 Joined: 29-March 07 From: Maple Grove, MN Member No.: 7,632 Region Association: Northstar Region |
I'm curious if anyone here has ever put some sort of electric heater into their 914. 914-6 heat exchangers, or equivalent, are $1500+. A header can be had for $400 and increases performance. (IMG:style_emoticons/default/biggrin.gif) I can live without heat per se, but I will really need a defog option in my car for rainy days. Anyone rigged something up? Care to share?
alpha434 |
Sep 19 2007, 11:35 PM
My member number is no coincidence. Group: Members Posts: 3,154 Joined: 16-December 05 From: Denver, CO Member No.: 5,280 Region Association: Rocky Mountains |
I was serious... Where does the exhaust go? I might like that device- unless it shouldn't be used in a confined space...
Rand |
Sep 20 2007, 02:21 PM
I was serious... Where does the exhaust go? I might like that device- unless it shouldn't be used in a confined space... It's catalytic and safe for indoor use. Not enough exhaust / carbon monoxide to worry about. It can be used in a confined space (unless you're planning on sleeping with it in an airtight box). Crack a window if you're inside long enough to worry about it using up your oxygen. My car isn't that air tight. Not an issue. |
Lo-Fi Version | Time is now: 11th June 2024 - 04:37 PM |
