How do I remove the switches on the dash? |
HeavyHeavy |
Aug 10 2006, 09:25 AM
Member Group: Members Posts: 62 Joined: 7-June 06 From: Albuquerque Member No.: 6,177 |
Hello.
I want to remove the metal dash trim plates from my dash. You know the ones that are covered with the basket weave vinyl. It looks like I'll need to remove the switches for the lights and windshield wipers and the cigarette lighter. Can someone tell me what I'll need to do to remove those? Thanks |
TINCAN914 |
Aug 10 2006, 09:32 AM
Summer's Commin... Group: Members Posts: 2,440 Joined: 18-August 05 From: Colorado Springs, CO. Member No.: 4,611 Region Association: Rocky Mountains |
Unscrew the knobs. Once off, there is a washer looking plate with two small grooves towards the center hole. If you have a set of needle nose pliers, put those tips in those grooves, and turn counter clockwise, the center is threaded for the switch. keep turning and the washer will come off. (IMG:style_emoticons/default/smile.gif)
Lavanaut |
Aug 2 2007, 07:51 PM
Hungry Mind : Thirsty Gullet Group: Members Posts: 916 Joined: 20-June 06 From: Bend, OR Member No.: 6,265 Region Association: Pacific Northwest |
Unscrew the knobs. Once off, there is a washer looking plate with two small grooves towards the center hole. I just want to be sure here ~ the knobs themselves (headlights, hazards, fogs) unscrew? I tried with a fair amount of force and they didn't budge. Does it matter if they're pulled out or not? I'm afriad I'm going to break it. (IMG:style_emoticons/default/unsure.gif) I must not fear, for fear is the mind killer. |
So.Cal.914 |
Sep 25 2007, 12:30 PM
"...And it has a front trunk too." Group: Members Posts: 6,588 Joined: 15-February 04 From: Low Desert, CA./ Hills of N.J. Member No.: 1,658 Region Association: None |
Unscrew the knobs. Once off, there is a washer looking plate with two small grooves towards the center hole. I just want to be sure here ~ the knobs themselves (headlights, hazards, fogs) unscrew? I tried with a fair amount of force and they didn't budge. Does it matter if they're pulled out or not? I'm afriad I'm going to break it. (IMG:style_emoticons/default/unsure.gif) I must not fear, for fear is the mind killer. Yes, Muadib, they do unscrew counter clockwise. Use some force...Oooop's wrong book. QUOTE Can anyone suggest any tips/tricks to prevent the housings for these knobs, that sit behind the dash face, from falling and becoming unreachable when you remove the knobs themselves? I can't see a way to get at some of them at all from behind. You eather have A/C or you have sasquatch hands, eather way the wiring loom usually held mine in place. |
Lo-Fi Version | Time is now: 2nd June 2024 - 06:47 AM |
