Turning on electrical system w/o fuel tank in place, Bad idea? |
Lavanaut |
Sep 25 2007, 12:20 PM
Hungry Mind : Thirsty Gullet Group: Members Posts: 916 Joined: 20-June 06 From: Bend, OR Member No.: 6,265 Region Association: Pacific Northwest |
I just finished reassembling the blower and heater flappers in the front trunk. Before I put the fuel tank back in, I'd like to test to make sure it's working (I replaced the heater controls in the cockpit as well). I started thinking that turning the ignition to the on position might trigger the fuel pump...and that stopped me in my tracks. I'm definitely *not* talking about trying to start the car...just get the electrical going to test the blower up front.
I've got fuel line extensions hooked up to the lines that emerge from the center tunnel, and have those taped off. Newb out, thanks! (IMG:style_emoticons/default/smile.gif) |
Cap'n Krusty |
Sep 25 2007, 12:49 PM
If it makes you feel better, just remove the 2 fuel system relays on the engine compartment relay board. If you're not sure which 2, remove all 3. If you have a Pertronix, remove the wire(s) from the 15 (+) terminal of the coil, too. The Cap'n
Lo-Fi Version | Time is now: 10th June 2024 - 10:54 AM |
