> brake light always on....., nothing changes when you step on the brake pedal
jonferns
post Sep 25 2007, 07:08 PM
ok, stupid for not noticing this in the 5 or so months that we have owned this car....
once you put the key in the ignition, and turn it a little bit, the brake lights come on....and when you step on the brake, nothing changes....not brighter (or dimmer)...
this is always like this, car on or off.....brake switch? any ideas? thanks alot -JON (IMG:style_emoticons/default/biggrin.gif)
Cap'n Krusty
post Sep 25 2007, 07:45 PM
Cap'n Krusty
Actually, the arm of the switch should be on the side of the washer AWAY from the master cylinder (i.e., toward the driver), ans loses contact with that washer when the pedal is depressed, allowing the lever to move away from the driver ans turn the light on. I'd suggest that maybe the switch arm is on the wrong side of the washer, allowing it to be in the on position all the time. Easily fixed, once you see how it is under there. The Cap'n
- Lo-Fi Version Time is now: 6th July 2025 - 01:29 PM
