> Determining proper valve clearance, on a custom build
3liter914-6
post Oct 4 2007, 10:29 PM
Master of Clueless Posts
Almost 2 years ago, my brother purchased a 2270 for his 914. I installed it, but really haven't had a chance to run it until this week. On startup, there's a little ticking noise that sounds like a loose valve to me, so I wanted to make sure I have the clearances set correctly. It's been so long since I set them that I don't remember what spec I used, but thinking about it now, I'm not sure what spec to use.
It's a 2270cc engine built by a member of this board that I don't think visits/posts much anymore.
Here are the specs I was able to piece together from old posts here and elsewhere:
2270, 78.4x96, T1 rods - Scat I-beams. Reduced base-circle 163/86B webcam. 9.1:1
1.7L rockers, 911 valve adjusters, with about 60-thou taken off for clearance.
1.8L head with (48x38) valves
So, what spec do I use to adjust the valves? It's a 1.8L head, so do I use that? or...? I guess the question is, what determines what valve clearance you use on a non-stock engine.
Thanks for any information!
Aaron Cox
post Oct 4 2007, 11:36 PM
Professional Tinkerer
(IMG:style_emoticons/default/agree.gif) what she ^^ said.
Im with alice.
3liter914-6
post Oct 5 2007, 11:25 AM
Thanks for the quick responses guys. Knowing that it came down to the pushrods, I was find a post describing which ones he used (Aircooled.net's HD aluminum). They say to set them at .006, so I've got the feeler gauges, and I'm headed out there. I'll do a sanity check to make sure they're the rods I expect, but I should be good.
Thanks again.
- Lo-Fi Version Time is now: 11th March 2026 - 10:52 PM
