| J9146 |
Oct 6 2007, 02:37 PM
Newbie ![]() Group: Members Posts: 10 Joined: 13-May 05 From: San Diego CA Member No.: 4,073 |
Can some one post a picture of a stock 2.0 distributor in the motor?
I am having trouble with condenser hitting the tin so I can't adjust the timing. I set up drive gear from the book to 12 degrees. |
| jasons |
Oct 6 2007, 07:32 PM
Jackstand Extraordinaire ![]() ![]() ![]() ![]() Group: Members Posts: 2,011 Joined: 19-August 04 From: Scottsdale, AZ Member No.: 2,573 Region Association: None |
Your dizzy drive may still not be indexed correctly. You can gingerly re-index the drive by inserting something into it and pulling it up and index it to where it needs to be. I did it with a 1/4" socket headed allen bit on an extension. I don't remember the size, but it was SAE not metric. It fit pretty snug in the hole in the center of the drive. I just put it in there, torqued it enough for it to get a grip, pulled up and rotated the drive one or two teeth.
I would think moving the plug wires could be a problem if you have DJet. Because, the trigger points in the dizzy wouldn't be in sync with the ignition order. |
J9146 I need help with distributor installation Oct 6 2007, 02:37 PM
jk76.914 Try moving each wire one location left or right, a... Oct 6 2007, 02:45 PM
Spoke Hope these help. Oct 6 2007, 06:12 PM
J9146 Thanks Jerry when I pulled the condenser off I for... Oct 7 2007, 09:14 PM![]() ![]() |
Lo-Fi Version | Time is now: 12th March 2026 - 11:00 PM |
