| jaybird840 |
Oct 6 2007, 07:04 PM
Member ![]() ![]() Group: Members Posts: 163 Joined: 27-September 06 From: Austin, TX Member No.: 6,927 Region Association: Southwest Region |
Man, what a pain!!! I started the install on my Mallory Unilite today, and it was anything but smooth. I think someone mentioned "dimpling" their sheet metal to make room for the larger dizzy head. (IMG:style_emoticons/default/smash.gif) (IMG:style_emoticons/default/smash.gif) (IMG:style_emoticons/default/sawzall-smiley.gif) I hope I didn't damage the head underneath the tin. I finally got the danged thing in (or so I thought) to the point that I could rotate the dizzy, but come to find out when I went to fire it up, I didn't have it seated properly. So, after more cussing, it finally slipped all the way in--but the rotor spins freely still. I guess it's still not in all the way, huh? Last, now that my timing is completely Fuched, do I pull the valve cover and watch until #1 rocks? I have my flywheel timing mark to guide me by after that, I guess to find TDC on #1. Any advice would be warmly welcomed.
--bird |
| Chris Hamilton |
Oct 6 2007, 09:05 PM
Senior Member ![]() ![]() ![]() Group: Members Posts: 611 Joined: 7-March 06 From: Berkeley, CA Member No.: 5,687 |
I didn't have to do a huge amount of denting into the tins for my unilite. Timing was easy because I just recorded what my old dizzy was at, and tried to make this match as closely as possible. Did end up a bit advanced, but not badly. Really smooth install for me, doing the wiring on my nology and MSD parts was more difficult.
If you have any trouble finding TDC, just pull the valve cover and you'll see everything you need to know. A manual starter button could be invaluable to you, so scoop up one of those too so you don't have to prybar the flywheel. |
jaybird840 AAAAAAAAAAARRRRRRRRRRRGGGGGHHHHHHH! Oct 6 2007, 07:04 PM
Jake Raby These are not typical results... More than likely ... Oct 6 2007, 08:48 PM
SLITS If you marked the flywheel or blower impeller ....... Oct 7 2007, 09:11 AM![]() ![]() |
Lo-Fi Version | Time is now: 14th March 2026 - 04:09 AM |
