| smontanaro |
Oct 6 2007, 09:50 PM
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,190 Joined: 3-June 05 From: Evanston, IL Member No.: 4,197 Region Association: Upper MidWest |
I got to wondering if there is a relatively easy way to tell if I have T cams or E cams in my 914/6. The part numbers are different (T == 901.105.133.01, E == 901.105.181.00). If I was to remove a valve cover would I be able to see a part number if I rotated the crank? I have no particular reason to believe I have an E cam. I am just curious.
Thanks, Skip Montanaro |
| brp986s |
Oct 6 2007, 10:23 PM
Member ![]() ![]() Group: Members Posts: 434 Joined: 27-September 07 From: los angeles Member No.: 8,167 |
you can't see the part # with the cam installed in the engine (as I recall), but should be be able to tell by valve lift. make a quickie depth gauge to measure lift at tdo. A T cam is ~1mm, vs E several mm.
smontanaro How to tell if I have T or E cams? Oct 6 2007, 09:50 PM
Cap'n Krusty Yes. Remember, the part numbers are different lef... Oct 6 2007, 10:10 PM![]() ![]() |
Lo-Fi Version | Time is now: 16th April 2026 - 02:58 AM |
