Full Version: How to tell if I have T or E cams?
smontanaro
I got to wondering if there is a relatively easy way to tell if I have T cams or E cams in my 914/6. The part numbers are different (T == 901.105.133.01, E == 901.105.181.00). If I was to remove a valve cover would I be able to see a part number if I rotated the crank? I have no particular reason to believe I have an E cam. I am just curious.
Thanks,
Skip Montanaro
Cap'n Krusty
Yes. Remember, the part numbers are different left and right. Remove either lower cam cover, and look for the number with a flashlight. E cams have significantly more top end power, and less bottom end, something that's obvious when driving examples of both, one after the other. The Cap'n
brp986s
you can't see the part # with the cam installed in the engine (as I recall), but should be be able to tell by valve lift. make a quickie depth gauge to measure lift at tdo. A T cam is ~1mm, vs E several mm.
