| smontanaro |
Oct 6 2007, 09:50 PM
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,190 Joined: 3-June 05 From: Evanston, IL Member No.: 4,197 Region Association: Upper MidWest |
I got to wondering if there is a relatively easy way to tell if I have T cams or E cams in my 914/6. The part numbers are different (T == 901.105.133.01, E == 901.105.181.00). If I was to remove a valve cover would I be able to see a part number if I rotated the crank? I have no particular reason to believe I have an E cam. I am just curious.
Thanks, Skip Montanaro |
| Cap'n Krusty |
Oct 6 2007, 10:10 PM
Cap'n Krusty ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 10,794 Joined: 24-June 04 From: Santa Maria, CA Member No.: 2,246 Region Association: Central California |
Yes. Remember, the part numbers are different left and right. Remove either lower cam cover, and look for the number with a flashlight. E cams have significantly more top end power, and less bottom end, something that's obvious when driving examples of both, one after the other. The Cap'n
| brp986s |
Oct 6 2007, 10:23 PM
Member ![]() ![]() Group: Members Posts: 434 Joined: 27-September 07 From: los angeles Member No.: 8,167 |
you can't see the part # with the cam installed in the engine (as I recall), but should be be able to tell by valve lift. make a quickie depth gauge to measure lift at tdo. A T cam is ~1mm, vs E several mm.
Lo-Fi Version | Time is now: 15th April 2026 - 11:28 PM |
