> Boxster Transmission into 914?
roamer
post Oct 6 2007, 06:02 PM
Ok Guys-
I have searched around the board for some time as I begin formulating my plan for an STI swap into a 914. One of my primary concerns is the transmission. The 901 will not withstand my power goals (~450hp), nor will a 915. A 4-speed 930 transmission is inappropriate for the subie powerband. I know that a G50/xx will work, but what about the transmission from the boxster? It is my understanding that the torque capacity of these transmissions are equivalent to the G50 and it seems to me that it would be a better solution since it was designed for a mid-engined car.
Any guidance would be greatly appreciated!
Thank you.
post Oct 7 2007, 03:57 PM
Resident German
QUOTE(roamer @ Oct 6 2007, 04:02 PM) *
i know of at least two 914s (seen and touched both) that have double that HP and both of which run a 930 gear box ...
(IMG:style_emoticons/default/shades.gif) Andy
roamer
post Oct 7 2007, 04:27 PM
QUOTE(SirAndy @ Oct 7 2007, 05:57 PM) *
Andy- Unfortunately the 930 tranny won't match well to powerband of the 2.5 turbo.
The 951 tranny also seems like more fabrication work than is reasonable. I am not trying to invent a new way, just find a way that works best.
post Oct 7 2007, 05:16 PM
Resident German
QUOTE(roamer @ Oct 7 2007, 02:27 PM) *
could you re-gear it to be a better match?
(IMG:style_emoticons/default/idea.gif) Andy
roamer   Boxster Transmission into 914?   Oct 6 2007, 06:02 PM
GeorgeRud   It's been done, but it takes a buttload of fab...   Oct 6 2007, 06:06 PM
Dave_Darling   There's a thread on the Pelican 914 BBS with a...   Oct 6 2007, 06:45 PM
Beachbum   Ok Guys- I have searched around the board for so...   Oct 6 2007, 08:01 PM
davep   Some of these can be used I guess. You have to be ...   Oct 6 2007, 08:09 PM
neo914-6   search here or Pelican for abc914 or 914abc, it is...   Oct 6 2007, 08:35 PM
Chris Hamilton   Would it be more or less expensive than the awesom...   Oct 6 2007, 09:11 PM
wbergtho   Those are G50 series boxes and need to be mounted...   Oct 6 2007, 10:49 PM
roamer   So if I understand everyone correctly, the Boxster...   Oct 7 2007, 12:45 PM
Brando   Could try a 951 transmission or 968 transmission. ...   Oct 7 2007, 12:56 PM
BMartin914   Could try a 951 transmission or 968 transmission....   Oct 7 2007, 03:50 PM
Brando   On opposite sides yes. Supposedly the spline count...   Oct 7 2007, 03:56 PM
SirAndy   my power goals (~450hp) i know of at least two 9...   Oct 7 2007, 03:57 PM
roamer   my power goals (~450hp) i know of at least two ...   Oct 7 2007, 04:27 PM
SirAndy   Andy- Unfortunately the 930 tranny won't mat...   Oct 7 2007, 05:16 PM
Brando   Well... Hello Boxster trans, goodbye rear trunk...   Oct 7 2007, 04:28 PM
Twystd1   You can buy darn near any gear set imaginable for ...   Oct 7 2007, 06:39 PM
Brett W   The Boxster tranny has no provision for a starter....   Oct 7 2007, 08:53 PM
roamer   Thanks Guys! 4 speeds will be tough to match ...   Oct 8 2007, 11:45 AM
Brett W   How much torque do you anticipate making? The Aud...   Oct 8 2007, 04:41 PM
roamer   How much torque do you anticipate making? The Au...   Oct 8 2007, 04:53 PM
Brett W   Put a 901 on there and run it. You will be fine. ...   Oct 8 2007, 05:48 PM
- Lo-Fi Version Time is now: 4th July 2025 - 12:07 AM
