| Mike Knox |
Oct 7 2007, 03:55 PM
MikeTuba ![]() ![]() Group: Members Posts: 162 Joined: 17-October 03 From: Ashland, OR Member No.: 1,258 Region Association: Pacific Northwest |
As many of you are aware, for several years I've been converting my 1974 to a 3.2 914/6. For nearly two years it's been on jackstands. Well I'm getting close to completion, and I need to source up to date heat exchangers.
I have a set of used OEM exchangers, but the flange thickness is different, (IMG:style_emoticons/default/headbang.gif) (thinner) and they won't work without spacers, or reseating all the head studs. So I need to find someone who can supply me a set that will work with a 3.2. Any guidance will be appreciated. |
| johnlush |
Oct 7 2007, 08:17 PM
What's all this then? ![]() ![]() Group: Members Posts: 376 Joined: 26-May 04 From: Cheyenne, WY Member No.: 2,108 Region Association: Rocky Mountains
Mike,
I think you have answered your own questions. Either swap out the studs or use spacers. Given the likelihood of problems removing the old studs I would be inclined to think spacers would be the best path. I would be interested in opinions of why this wouldn't be a viable solution. John |
Mike Knox Heat Exchangers for 914-6 Oct 7 2007, 03:55 PM
jim912928 I haven't installed my engine yet....but I got... Oct 7 2007, 07:27 PM
LarryR Here is a sweet set that patrick motorsports sells... Oct 7 2007, 08:12 PM
Mike Knox Hi John,
I tried the spacer route. It's hard... Oct 7 2007, 08:56 PM
ClayPerrine About 2 months ago I worked on a factory six that ... Oct 7 2007, 09:45 PM
Mike Knox Hi Clay,
Thanks for the input. This is the confid... Oct 7 2007, 10:02 PM
johnlush Mike, SnapOn has a collet style stud remover that ... Oct 7 2007, 10:29 PM
ClayPerrine
Mike, SnapOn has a collet style stud remover that... Oct 8 2007, 07:31 AM
Mike Knox Yep, when I sold the 2.0 engine that was originall... Oct 8 2007, 02:27 PM
iamchappy Another trick, when the stud is still hot, a touch... Oct 8 2007, 09:13 AM
Dave_Darling One note about the stainless Six exchangers: The ... Oct 8 2007, 06:07 PM
Eric_Shea Clay nailed it. Weld on nuts and remove studs. Oct 8 2007, 06:45 PM
Inspector People have been using the spacer trick on sixes ... Oct 9 2007, 08:55 AM
ClayPerrine
People have been using the spacer trick on sixes... Oct 9 2007, 09:29 AM
Inspector
People have been using the spacer trick on sixe... Oct 9 2007, 01:33 PM![]() ![]() |
Lo-Fi Version | Time is now: 15th March 2026 - 12:26 PM |
