| Mike Knox |
Oct 7 2007, 03:55 PM
MikeTuba ![]() ![]() Group: Members Posts: 162 Joined: 17-October 03 From: Ashland, OR Member No.: 1,258 Region Association: Pacific Northwest |
As many of you are aware, for several years I've been converting my 1974 to a 3.2 914/6. For nearly two years it's been on jackstands. Well I'm getting close to completion, and I need to source up to date heat exchangers.
I have a set of used OEM exchangers, but the flange thickness is different, (IMG:style_emoticons/default/headbang.gif) (thinner) and they won't work without spacers, or reseating all the head studs. So I need to find someone who can supply me a set that will work with a 3.2. Any guidance will be appreciated. |
| ClayPerrine |
Oct 7 2007, 09:45 PM
Life's been good to me so far..... ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Admin Posts: 16,542 Joined: 11-September 03 From: Hurst, TX. Member No.: 1,143 Region Association: NineFourteenerVille
About 2 months ago I worked on a factory six that has a 3.2 transplant. It has the factory heat exchangers on it, and they work fine. They are a little smaller than optimal, but the car pulls real strong.
To put them on, we had to replace all 12 studs on the exhaust ports. It is easy to do. Just get yourself a welder and 12 8x1.25 nuts. Put the nut on the stud, and weld it in place. I used a gas welding torch. After the nuts have cooled down, just use a socket to unscrew the stud. Then replace with a shorter stud and install the heat exchanger. |
Mike Knox Heat Exchangers for 914-6 Oct 7 2007, 03:55 PM
jim912928 I haven't installed my engine yet....but I got... Oct 7 2007, 07:27 PM
LarryR Here is a sweet set that patrick motorsports sells... Oct 7 2007, 08:12 PM
johnlush Mike,
I think you have answered your own question... Oct 7 2007, 08:17 PM
Mike Knox Hi John,
I tried the spacer route. It's hard... Oct 7 2007, 08:56 PM
Mike Knox Hi Clay,
Thanks for the input. This is the confid... Oct 7 2007, 10:02 PM
johnlush Mike, SnapOn has a collet style stud remover that ... Oct 7 2007, 10:29 PM
ClayPerrine
Mike, SnapOn has a collet style stud remover that... Oct 8 2007, 07:31 AM
Mike Knox Yep, when I sold the 2.0 engine that was originall... Oct 8 2007, 02:27 PM
iamchappy Another trick, when the stud is still hot, a touch... Oct 8 2007, 09:13 AM
Dave_Darling One note about the stainless Six exchangers: The ... Oct 8 2007, 06:07 PM
Eric_Shea Clay nailed it. Weld on nuts and remove studs. Oct 8 2007, 06:45 PM
Inspector People have been using the spacer trick on sixes ... Oct 9 2007, 08:55 AM
ClayPerrine
People have been using the spacer trick on sixes... Oct 9 2007, 09:29 AM
Inspector
People have been using the spacer trick on sixe... Oct 9 2007, 01:33 PM![]() ![]() |
Lo-Fi Version | Time is now: 15th March 2026 - 12:31 PM |
