| Mike Knox |
Oct 7 2007, 03:55 PM
MikeTuba ![]() ![]() Group: Members Posts: 162 Joined: 17-October 03 From: Ashland, OR Member No.: 1,258 Region Association: Pacific Northwest |
As many of you are aware, for several years I've been converting my 1974 to a 3.2 914/6. For nearly two years it's been on jackstands. Well I'm getting close to completion, and I need to source up to date heat exchangers.
I have a set of used OEM exchangers, but the flange thickness is different, (IMG:style_emoticons/default/headbang.gif) (thinner) and they won't work without spacers, or reseating all the head studs. So I need to find someone who can supply me a set that will work with a 3.2. Any guidance will be appreciated. |
| johnlush |
Oct 7 2007, 10:29 PM
What's all this then? ![]() ![]() Group: Members Posts: 376 Joined: 26-May 04 From: Cheyenne, WY Member No.: 2,108 Region Association: Rocky Mountains
Mike, SnapOn has a collet style stud remover that has worked well for me but Clay's method sounds good too and the heat from the torch may actually really help in them coming out. You are planning on supporting the HE's and the muffler with a bracket at the back end, right?
John |
| Mike Knox |
Oct 8 2007, 02:27 PM
Yep, when I sold the 2.0 engine that was originally in the car I kept the muffler bracket.
Mike |
Mike Knox Heat Exchangers for 914-6 Oct 7 2007, 03:55 PM
jim912928 I haven't installed my engine yet....but I got... Oct 7 2007, 07:27 PM
LarryR Here is a sweet set that patrick motorsports sells... Oct 7 2007, 08:12 PM
johnlush Mike,
I think you have answered your own question... Oct 7 2007, 08:17 PM
Mike Knox Hi John,
I tried the spacer route. It's hard... Oct 7 2007, 08:56 PM
ClayPerrine About 2 months ago I worked on a factory six that ... Oct 7 2007, 09:45 PM
Mike Knox Hi Clay,
Thanks for the input. This is the confid... Oct 7 2007, 10:02 PM
ClayPerrine
Mike, SnapOn has a collet style stud remover that... Oct 8 2007, 07:31 AM
iamchappy Another trick, when the stud is still hot, a touch... Oct 8 2007, 09:13 AM
Dave_Darling One note about the stainless Six exchangers: The ... Oct 8 2007, 06:07 PM
Eric_Shea Clay nailed it. Weld on nuts and remove studs. Oct 8 2007, 06:45 PM
Inspector People have been using the spacer trick on sixes ... Oct 9 2007, 08:55 AM
ClayPerrine
People have been using the spacer trick on sixes... Oct 9 2007, 09:29 AM
Inspector
People have been using the spacer trick on sixe... Oct 9 2007, 01:33 PM![]() ![]() |
Lo-Fi Version | Time is now: 15th March 2026 - 12:27 PM |
