| iamchappy |
Oct 8 2007, 04:38 PM
It all happens so fast! ![]() ![]() ![]() ![]() Group: Members Posts: 4,893 Joined: 5-November 03 From: minnetonka, mn Member No.: 1,315 Region Association: Upper MidWest |
Ok i found that I dont remember were every wire goes, and when I rewired my 14 pin connector to my 6's harness years ago a few wires got shifted around and I cant locate my master copy of were everything goes.
Anyway, does the heater lever wire go the little console light ground to make it turn on when the handle is pulled back. Or does it go to the fans ground to turn the fan on. Or does it act as ground wire that runs into the circuit boards fan relay ground pin via the 14 pin connector (IMG:style_emoticons/default/confused24.gif) . |
| iamchappy |
Oct 8 2007, 05:53 PM
Thanks Andy, My deductive reasoning sort of kinda assumed that conclusion.
Thanks for clearing it up. I will continue on. |
iamchappy Heater lever - wire Oct 8 2007, 04:38 PM
Ok i found that I dont remember were every wire g... Oct 8 2007, 04:46 PM
Dave_Darling Are you sure, Aaahndy? If so, then it's an ea... Oct 8 2007, 05:55 PM
swl wiring diagram in Haynes both early and late. On... Oct 8 2007, 06:43 PM
iamchappy
wiring diagram in Haynes both early and late. O... Oct 8 2007, 07:07 PM![]() ![]() |
Lo-Fi Version | Time is now: 14th April 2026 - 09:50 PM |
