| iamchappy |
Oct 8 2007, 04:38 PM
It all happens so fast! ![]() ![]() ![]() ![]() Group: Members Posts: 4,893 Joined: 5-November 03 From: minnetonka, mn Member No.: 1,315 Region Association: Upper MidWest |
Ok i found that I dont remember were every wire goes, and when I rewired my 14 pin connector to my 6's harness years ago a few wires got shifted around and I cant locate my master copy of were everything goes.
Anyway, does the heater lever wire go the little console light ground to make it turn on when the handle is pulled back. Or does it go to the fans ground to turn the fan on. Or does it act as ground wire that runs into the circuit boards fan relay ground pin via the 14 pin connector (IMG:style_emoticons/default/confused24.gif) . |
| Dave_Darling |
Oct 8 2007, 05:55 PM
914 Idiot ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 15,338 Joined: 9-January 03 From: Silicon Valley / Kailua-Kona Member No.: 121 Region Association: Northern California
Are you sure, Aaahndy? If so, then it's an early-car versus late-car thing. By 73, the heater lever wire grounded the coil in the heater blower relay, switching it on and sending power to the heater blower fan. Running the full current for the blower through that little wire seems to me to be asking for trouble of the "magic smoke" kind...
--DD |
iamchappy Heater lever - wire Oct 8 2007, 04:38 PM
Ok i found that I dont remember were every wire g... Oct 8 2007, 04:46 PM
iamchappy Thanks Andy, My deductive reasoning sort of kinda ... Oct 8 2007, 05:53 PM
swl wiring diagram in Haynes both early and late. On... Oct 8 2007, 06:43 PM
iamchappy
wiring diagram in Haynes both early and late. O... Oct 8 2007, 07:07 PM![]() ![]() |
Lo-Fi Version | Time is now: 14th April 2026 - 11:29 PM |
