> Another 3.0 liter swap, Please clarify a few things.
914chris
post Oct 10 2007, 03:19 PM
I have an original 2.0 liter six. I bought a 3.0 liter with webers and am going to do the swap. I have researched this forum and what to confirm/clarify if I am getting things right.
From what I understand I need to do the following:
1) Get a flywheel/clutch setup from Kennedy. Can I use the 3.0 liter flywheel with an adapter? It is a 9 bolt flywheel. Is there a reason to use the flywheel from Kennedy, over the adapter ring gear? I have read that the Kennedy flywheel is welded up and re-drilled, not sure if I want to go that way.
2) Modify the 3.0 liter oil cooler with a 90 degree to clear the trailing arm. Is the 3.0 liter cooler different than my cooler from the stock 2.0? Do I need the engine cooler even if I want to add a front mounted cooler? Will I need a front mounted cooler?
3) Do I need to modify the throttle linkage on the 3.0 liter? It came out of a 911. I would think I need some of my linkage parts from the original six, but not sure.
I plan to upgrade the fuel lines in the tunnel with the stainless setup from one of the guys on the board.
Is there anything else I should do while I have things apart?
Thanks for you help.
Series9
post Oct 11 2007, 08:20 AM
Lesbians taste like chicken.
I use the stock flywheel with the ring gear adapter and Centerforce clutch. Either way. Both work.
I would modify the 3.0 oil cooler because the ID of the supply pipe is larger on the later coolers. The 3.0 oil pump has a substantially larger capacity than the 2.0 pump.
- Lo-Fi Version Time is now: 1st July 2026 - 12:27 AM
