Springs and Perches |
andys |
Oct 11 2007, 04:19 PM
Advanced Member Group: Members Posts: 2,165 Joined: 21-May 03 From: Valencia, CA Member No.: 721 Region Association: None |
I figured the race crowd would be the best place to seek some info. I have the Koni Yellows in this (poor) photo (with blue tape attached). Since this is a V8 car, I want to be able to swap springs and set hide heights easily when dialing in the handling. I'll be doing some track day testing to get things working right. What adjustable perches will fit these shocks? Will they interfere with the keeper that's welded to the shock body (I think the springs will be shorter than that)? How about springs (diameter, length, source)? I don't intend to lower the car any more than keeping the trailing arms parallel to the ground. This is not going to be a track car; mostly street driven.
Thanks, Andys Attached thumbnail(s) |
J P Stein |
Oct 11 2007, 07:30 PM
Irrelevant old fart Group: Members Posts: 8,797 Joined: 30-December 02 From: Vancouver, WA Member No.: 45 Region Association: None |
Yes, 10 inch. You may be able to slip the collars on from the top. Mine are the longer ones. When set, they would be about where your spring support sits....maybe a bit higher....by my eyeball. A pic of them on the car. The springs are attached to the top mounts. Attached thumbnail(s) |
Lo-Fi Version | Time is now: 28th May 2024 - 09:59 PM |
