Springs and Perches |
andys |
Oct 11 2007, 04:19 PM
Advanced Member Group: Members Posts: 2,165 Joined: 21-May 03 From: Valencia, CA Member No.: 721 Region Association: None |
I figured the race crowd would be the best place to seek some info. I have the Koni Yellows in this (poor) photo (with blue tape attached). Since this is a V8 car, I want to be able to swap springs and set hide heights easily when dialing in the handling. I'll be doing some track day testing to get things working right. What adjustable perches will fit these shocks? Will they interfere with the keeper that's welded to the shock body (I think the springs will be shorter than that)? How about springs (diameter, length, source)? I don't intend to lower the car any more than keeping the trailing arms parallel to the ground. This is not going to be a track car; mostly street driven.
Thanks, Andys Attached thumbnail(s) |
Dave_Darling |
Oct 12 2007, 10:17 AM
I got a setup to fit Koni Yellows from Pelican years ago, before I started working for them. IIRC, it's the standard setup for threaded-collar adjustable perches. I don't recall if it's Weltmeister or not. The inside of the collar has a machined "step" to fit over the welded-on support; part of the collar goes down past the support and part of it is above the support.
You can see if Glenn with Pelican can hook you up, or check with Jason over at Paragon. And I'm sure the Doc or Dave at GPR also have one or two ideas... --DD |
andys |
Oct 12 2007, 10:45 AM
I got a setup to fit Koni Yellows from Pelican years ago, before I started working for them. IIRC, it's the standard setup for threaded-collar adjustable perches. I don't recall if it's Weltmeister or not. The inside of the collar has a machined "step" to fit over the welded-on support; part of the collar goes down past the support and part of it is above the support. You can see if Glenn with Pelican can hook you up, or check with Jason over at Paragon. And I'm sure the Doc or Dave at GPR also have one or two ideas... --DD Dave, Thanks, that sounds like exactly what I'm looking for. I'll check it out. Are those perches made for the stock spring diameter? What I need to do, is measure all the pertinant diameters and positions so I can talk turkey. I know AFCO makes 2 5/8" ID springs. Andys |
Lo-Fi Version | Time is now: 9th June 2024 - 07:38 AM |
