| Joe Ricard |
Oct 11 2007, 09:13 PM
CUMONIWANNARACEU ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 6,811 Joined: 5-January 03 From: Gautier, MS Member No.: 92 |
Last week I was contacted by some of you E-bayers because the white 73 2.0L carbed and 916 kit was out for auction.
Well Finally met up with the owner today. He drove the car from Biloxi to my house (20 Miles). I looked at all the trouble spots and found a few of the normal things. rust bubbles around bottom of windshield perferation at both rear trunk corners .50 cent piece each. surface rust in floor and floors have been replaced once in the cars life time. Still solid and decent repair not CCW stuff. Flares are bonded and glassed in as are front and rear 916 bumpers. Front trunk needs cleaning and repaint Engine runs but could use a leaner jet job which would bring a bunch more power. (40 IDF's) and could use a synch. Longs were OK but I couldn't see much Battery tray was removed and battery was not well mounted in the rear trunk. That's about all the bad and now the good Trans shifted very good Interior was nice seats were nice with original material Drivers door is early Pasenger side I couldn't tell but looked late. no rust on either Trunk lids very nice roof was ok sound padding in both engine compartment and rear trunk floor stock brakes with 19mm MC was very firm Wheels were at least 6" width and 195/50-15 multi season Manta exhaust and stock HE's with most of the heat stuff. No Auxillary blower. |
| Joe Ricard |
Oct 13 2007, 01:53 PM
Might as wel go off topic
Made the splitter with a sheet of cheap luan 1/8" thick. Cut it to begin at the front edge of the steering rack cover and then mak it as long as you want. I only went out as far as the bumper edge. Some marine adhesive to glue luan to air dam. and then glass on both sides and up onto the air dam on the back side. Strong enough that I could have my 7 yr old stand on it without brace rods. Ended up 4" off the ground at the leading edge. Glass on both sides of the wood and some marine |
Joe Ricard 73 appraisal please Oct 11 2007, 09:13 PM
Joe Ricard Engine Oct 11 2007, 09:16 PM
Joe Ricard wheels Oct 11 2007, 09:23 PM
Aaron Cox empi 8 spokes are 5.5" wide :)
i stand corre... Oct 11 2007, 10:10 PM
sixnotfour Caroll Shelby "Anaconda" Wheels 15x7 . T... Oct 11 2007, 10:18 PM
Dan (Almaden Valley) those wheels are an old "minilite" knock... Oct 11 2007, 10:24 PM
jd74914
those wheels are an old "minilite" knoc... Oct 11 2007, 11:09 PM
sixnotfour RE: 73 appraisal please Oct 12 2007, 12:28 AM
rhodyguy how much does the owner expect to see for the car ... Oct 12 2007, 09:04 AM
cooltimes Since you did ask for an evaluation and he DID dri... Oct 12 2007, 10:05 AM
Joe Ricard Well I would think 3K tops.
Going to need quite a... Oct 12 2007, 05:24 PM
Blood red 914-6gt 6500? In the words of Shaggy...Zoiks. Maybe 4500 t... Oct 12 2007, 05:39 PM![]() ![]() |
Lo-Fi Version | Time is now: 2nd April 2026 - 04:42 PM |
