| trojanhorsepower |
Dec 9 2003, 01:01 PM
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,051 Joined: 21-September 03 From: Marion, NC Member No.: 1,179 Region Association: None |
Help! (IMG:style_emoticons/default/headbang.gif)
This is pissing me off. Just for the record I did nothing to this motor (some one else did)inside the case. That said I have a 74 2.0 T-IV on an engine stand. I am just about ready to do the tin when I think lets double check the timing and get the distributor on. I start to turn the motor and find TDC for #1 then adjust the valves, then rotate the crank 180 deg. and Holly Crap there is like a 1/8th of an inch play in the intake rocker!! Piston is at or near the bottom. Does this mean what I think it means (cam is not in there right)? Some body, please tell me the obvious thing that I am over looking or doing wrong! (IMG:style_emoticons/default/headbang.gif) Thanks -Pete |
| Brad Roberts |
Dec 11 2003, 01:34 PM
914 Freak! ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 19,148 Joined: 23-December 02 Member No.: 8 Region Association: None |
Damn.. now I need to leave...DOH!
B |
trojanhorsepower Timing Dec 9 2003, 01:01 PM
KenH Make sure you are turning the crank in the proper ... Dec 9 2003, 01:13 PM
trojanhorsepower OK I have been turning it CW if that is correct, b... Dec 9 2003, 01:17 PM
trojanhorsepower OK turning the motor CW and the intake valve opens... Dec 9 2003, 07:02 PM
trojanhorsepower That is really sweat, 58 views and nobody wants to... Dec 10 2003, 04:57 PM
thesey914
trojanhorsepower OK I know that I am not being clear.
Brad no one w... Dec 11 2003, 01:31 PM
trojanhorsepower Marks up
Piston up Dec 11 2003, 01:34 PM
trojanhorsepower Rotate 180 deg. CW piston is down intake is slight... Dec 11 2003, 01:36 PM
Brad Roberts Pushrods are not sitting in the lifters correctly.... Dec 11 2003, 01:36 PM
Brad Roberts I rotate the engines over on their side when I dro... Dec 11 2003, 01:38 PM
trojanhorsepower damn try again Dec 11 2003, 01:39 PM
trojanhorsepower These pics are not helping.
I am going back to th... Dec 11 2003, 01:44 PM
Brad Roberts Check the push rods............
B Dec 11 2003, 01:46 PM
trojanhorsepower I went and pulled the rocker arms and checked the ... Dec 11 2003, 02:16 PM
Jake Raby Sounds like you are starting at "overlap" not at "... Dec 11 2003, 02:19 PM
Brad Roberts CW facing the fan or CW facing the flywheel ?
B Dec 11 2003, 02:19 PM
trojanhorsepower CW facing the fan Dec 11 2003, 02:26 PM
Brad Roberts Correct. It sounds like you are not starting at nu... Dec 11 2003, 02:30 PM
trojanhorsepower Brad, Jake
Thanks for all the help guys.
I will ... Dec 11 2003, 02:39 PM
Brad Roberts The fan turns CW while facing it. In the car.. I g... Dec 11 2003, 02:42 PM
Jake Raby We are confusing him....
the engines motion is cl... Dec 11 2003, 02:53 PM
trojanhorsepower OK I went out and spun it again looking at #3
Sti... Dec 11 2003, 02:58 PM
Jake Raby If that happens turning it CW and all the pushrods... Dec 11 2003, 04:58 PM
trojanhorsepower Sorry guys, I was called away form the computer.
... Dec 11 2003, 09:11 PM
Jake Raby My number is 706 219 4874. I'm here till 3 Am ... Dec 11 2003, 09:14 PM
trojanhorsepower Running home to get cell phone (free long distance... Dec 11 2003, 09:18 PM
Jake Raby Try to ring me again...... I heard you beep throug... Dec 11 2003, 09:50 PM
Brad Roberts I still say pushrods.
b Dec 12 2003, 12:24 AM
Jake Raby Told him to triple check them..... Dec 12 2003, 09:48 AM
Gint SO?!?! The 914 Soap Opera. Don't kee... Dec 12 2003, 11:00 AM
trojanhorsepower I have been away for a while, sorry it has taken m... Dec 12 2003, 06:04 PM![]() ![]() |
Lo-Fi Version | Time is now: 13th June 2026 - 05:03 AM |
