| 914chris |
Oct 10 2007, 03:19 PM
Newbie ![]() Group: Members Posts: 23 Joined: 30-August 05 From: Santa Clarita, CA Member No.: 4,701 Region Association: None |
I have an original 2.0 liter six. I bought a 3.0 liter with webers and am going to do the swap. I have researched this forum and what to confirm/clarify if I am getting things right.
From what I understand I need to do the following: 1) Get a flywheel/clutch setup from Kennedy. Can I use the 3.0 liter flywheel with an adapter? It is a 9 bolt flywheel. Is there a reason to use the flywheel from Kennedy, over the adapter ring gear? I have read that the Kennedy flywheel is welded up and re-drilled, not sure if I want to go that way. 2) Modify the 3.0 liter oil cooler with a 90 degree to clear the trailing arm. Is the 3.0 liter cooler different than my cooler from the stock 2.0? Do I need the engine cooler even if I want to add a front mounted cooler? Will I need a front mounted cooler? 3) Do I need to modify the throttle linkage on the 3.0 liter? It came out of a 911. I would think I need some of my linkage parts from the original six, but not sure. I plan to upgrade the fuel lines in the tunnel with the stainless setup from one of the guys on the board. Is there anything else I should do while I have things apart? Thanks for you help. |
| jeff |
Oct 13 2007, 04:09 PM
Member ![]() ![]() Group: Members Posts: 256 Joined: 17-January 04 From: thousand oaks,ca Member No.: 1,570 |
What is the typical cost of doing pistons/cams?I'm guessing 10:1 for the street ?What lift/duration are the hot rod cams?My supposedly rebuilt 3.2 just failed its leakdown so i'm going to take a lok into thr engine sometime soon
914chris Another 3.0 liter swap Oct 10 2007, 03:19 PM
J P Stein I have an original 2.0 liter six. I bought a 3.0 l... Oct 10 2007, 06:11 PM
Cap'n Krusty Make sure the cams are appropriate for carbs. The... Oct 10 2007, 07:24 PM
Series9 I use the stock flywheel with the ring gear adapte... Oct 11 2007, 08:20 AM
rfuerst911sc
I use the stock flywheel with the ring gear adapt... Oct 11 2007, 11:27 AM
Series9
I use the stock flywheel with the ring gear adap... Oct 11 2007, 02:18 PM
rfuerst911sc Thank you. Oct 11 2007, 04:44 PM
914chris Thanks Guys,
I think I will get the cooler convert... Oct 11 2007, 09:02 PM
rfuerst911sc
Thanks Guys,
I think I will get the cooler conver... Oct 12 2007, 03:21 PM
brp986s I believe the fitting on the scavenge line is too ... Oct 12 2007, 09:06 PM
J P Stein
What is the typical cost of doing pistons/cams?I... Oct 13 2007, 05:58 PM
914chris Just got my clutch kit.
KEP stage II pressure plat... Nov 9 2007, 12:40 AM
Travis Neff why not just take the 914-6 oil cooler of the old ... Nov 9 2007, 12:49 AM![]() ![]() |
Lo-Fi Version | Time is now: 1st July 2026 - 12:24 AM |
