Two broken windshields...third time a charm?, Local glass installers using PPG |
Bogaat |
Oct 12 2007, 08:25 AM
Member Group: Members Posts: 195 Joined: 8-January 07 From: Charleston, SC Member No.: 7,436 |
I have had two different glass companies try to install a new windshield and they both broke them when installing the trim. Luckily, I didn't try to do the install myself! They both used the PPG glass. It is tight to the clips on every side once installed...no room for wiggle. The first company said they wouldn't do another as they thought the PPG glass wasn't cut correctly. They compared it to my old glass and there were obvious differences in dimension. The second company is coming out with a new one at the end of the week. They both broke the glass when trying to force the trim into place...it is tight. The first installers cracked it dead center top and the second guys cracked it bottom right corner. Any suggestions on installing the trim and avoiding another break? The first guys used the 1/4' butyl and the second guys tried their urethane stuff. I have the correct spacers. I am taking the entire week off of work next week to get this car back on the road and would love to have a windshield! . Thanks guys!
(IMG:style_emoticons/default/beer3.gif) |
rfuerst911sc |
Oct 13 2007, 07:40 AM
Advanced Member Group: Members Posts: 2,158 Joined: 4-May 06 From: Dahlonega , Georgia Member No.: 5,980 Region Association: South East States |
I have had two different glass companies try to install a new windshield and they both broke them when installing the trim. Luckily, I didn't try to do the install myself! They both used the PPG glass. It is tight to the clips on every side once installed...no room for wiggle. The first company said they wouldn't do another as they thought the PPG glass wasn't cut correctly. They compared it to my old glass and there were obvious differences in dimension. The second company is coming out with a new one at the end of the week. They both broke the glass when trying to force the trim into place...it is tight. The first installers cracked it dead center top and the second guys cracked it bottom right corner. Any suggestions on installing the trim and avoiding another break? The first guys used the 1/4' butyl and the second guys tried their urethane stuff. I have the correct spacers. I am taking the entire week off of work next week to get this car back on the road and would love to have a windshield! . Thanks guys! (IMG:style_emoticons/default/beer3.gif) Just curious did the installers try to talk you into not useing the metal trim? The reason I ask is I will have to replace my windshield due to a small crack when I get the car painted and I've pretty much made up my mind to use the aftermarket rubber trim. I don't think there is an issue when useing the rubber trim? |
Bogaat |
Oct 13 2007, 07:30 PM
I have had two different glass companies try to install a new windshield and they both broke them when installing the trim. Luckily, I didn't try to do the install myself! They both used the PPG glass. It is tight to the clips on every side once installed...no room for wiggle. The first company said they wouldn't do another as they thought the PPG glass wasn't cut correctly. They compared it to my old glass and there were obvious differences in dimension. The second company is coming out with a new one at the end of the week. They both broke the glass when trying to force the trim into place...it is tight. The first installers cracked it dead center top and the second guys cracked it bottom right corner. Any suggestions on installing the trim and avoiding another break? The first guys used the 1/4' butyl and the second guys tried their urethane stuff. I have the correct spacers. I am taking the entire week off of work next week to get this car back on the road and would love to have a windshield! . Thanks guys! (IMG:style_emoticons/default/beer3.gif) Just curious did the installers try to talk you into not useing the metal trim? The reason I ask is I will have to replace my windshield due to a small crack when I get the car painted and I've pretty much made up my mind to use the aftermarket rubber trim. I don't think there is an issue when useing the rubber trim? They never considered it optional...however they all have tried and failed! I am hoping someone can provide some input on installing the trim (even with our junky aftermarket glass). The car will be on the road by the end of the week, so I am hoping there is some glass in the car! |
Lo-Fi Version | Time is now: 15th June 2024 - 04:23 PM |
