Carb fuel pump routing |
KaptKaos |
Oct 14 2007, 01:56 PM
Family Group: Members Posts: 4,009 Joined: 23-April 03 From: Near Wausau Member No.: 607 Region Association: Upper MidWest |
I am putting in new lines for my carbs. The hard line comes under the car, then connects to the old pumpt and filter. I am using the CB rotary pump and it's almost 12 inches long all in.
There is a mounting point for the fuel filter under the car, but if I try and mount the new filter there, then the lines under the car will be doing loops. Can i mount the pump underneath and then the filter above the tin? Is that a bad idea? Should I be doing this another way (other than moving the pump to the front). Let me know. Thanks! |
rhodyguy |
Oct 14 2007, 07:15 PM
Chimp Sanctuary NW. Check it out. Group: Members Posts: 22,084 Joined: 2-March 03 From: Orion's Bell. The BELL! Member No.: 378 Region Association: Galt's Gulch |
use a stock, big, square filter. if yours is like the cb i got, the short section of hose inbetween the carter filter and the pump has fixed, not removable clamps. you'll have to cut the line just to change the filter and the line will be shorter...everytime.
k |
KaptKaos |
Oct 14 2007, 07:48 PM
use a stock, big, square filter. if yours is like the cb i got, the short section of hose inbetween the carter filter and the pump has fixed, not removable clamps. you'll have to cut the line just to change the filter and the line will be shorter...everytime. k DOH! Too late. I will have to deal with that the next time. Oh well. Anyway, I made 2 jumpers for the power to the pump, one side with a male spade and the other a female spade. How do I know which side connects where on the CB pump? |
Lo-Fi Version | Time is now: 2nd June 2024 - 01:30 AM |
