Best way to weld side marker lights closed? |
flyloki |
Oct 23 2007, 12:46 PM
Member Group: Members Posts: 138 Joined: 20-October 03 From: 8:00 in Boise, Idaho Member No.: 1,264 |
About to send the car for paint and I want to weld the cowl seam and side marker light holes up. What's the best way to go about doing this?
Thanks |
VaccaRabite |
Oct 23 2007, 01:30 PM
En Garde! Group: Admin Posts: 13,465 Joined: 15-December 03 From: Dallastown, PA Member No.: 1,435 Region Association: MidAtlantic Region |
Welding shut the cowl seam is a bad idea, at least that is what the brain trust seems to think. I left mine.
Welding up marker lights. I cheated when I did mine. I cut a patch slightly larger then the hole, cleaned off all the paint and tar behind the fender, and lap-welded the hole shut. A little bit of body filler, and you'd never know they were there. I used this technique to close all the holes in the fender when I pulled out the AC. You can carefully cut a patch and butt weld them in, and then grind the weld flat - but I don't weld that well, and wanted them done. Zach |
Lo-Fi Version | Time is now: 6th June 2024 - 10:20 PM |
