Mallory Unilite Distributor, Installation in 914 2.0L questions.... |
Joseph Mills |
Mar 17 2003, 05:01 PM
on a Sonoma diet now... Group: Members Posts: 1,482 Joined: 29-December 02 From: Oklahoma City, OK Member No.: 39 |
Just a few questions. Waiting to receive this distributor. It is replacing a 009 and will be used with a Bosch blue coil and an MSD-5 electronic ignition (no rev-limiter). Any advantage gained by upgrading the coil or will it work just fine?
I know the unit is much larger than my 009. Anything special I need to be aware of for installation of the Mallory in a T4 engine (adaptors, clearance)? Is a "ballast resistor" required for this combination? If so, exactly what is a ballast resistor and what does it do? This will be my first time swapping out a distributor, so any info is appreciated. Joseph 75 2.0L AX bound |
Brad Roberts |
Mar 17 2003, 08:03 PM
914 Freak! Group: Members Posts: 19,148 Joined: 23-December 02 Member No.: 8 Region Association: None |
NOW.
I smacked the tin because I needed the dizzy at TDC. The pic above is with 30deg dialed in. Here is complete shot. B |
Lo-Fi Version | Time is now: 2nd June 2024 - 03:04 PM |
