> Timing, something out of whack
trojanhorsepower
post Dec 9 2003, 01:01 PM
Help! (IMG:style_emoticons/default/headbang.gif)
This is pissing me off. Just for the record I did nothing to this motor (some one else did)inside the case. That said I have a 74 2.0 T-IV on an engine stand. I am just about ready to do the tin when I think lets double check the timing and get the distributor on. I start to turn the motor and find TDC for #1 then adjust the valves, then rotate the crank 180 deg. and Holly Crap there is like a 1/8th of an inch play in the intake rocker!! Piston is at or near the bottom. Does this mean what I think it means (cam is not in there right)? Some body, please tell me the obvious thing that I am over looking or doing wrong! (IMG:style_emoticons/default/headbang.gif)
Thanks
-Pete
Gint
post Dec 12 2003, 11:00 AM
Mike Ginter
SO?!?! The 914 Soap Opera. Don't keep us in suspense. This is better'n T.V.
Did Pete call Jake? Did Jake diagnose the issue? Will Pete's car run soon?
Stay tuned for another thrilling episode of "As the TypeIV crank Turns".
P.S. - Beats working in this miserable pit.
trojanhorsepower   Timing   Dec 9 2003, 01:01 PM
KenH   Make sure you are turning the crank in the proper ...   Dec 9 2003, 01:13 PM
trojanhorsepower   OK I have been turning it CW if that is correct, b...   Dec 9 2003, 01:17 PM
trojanhorsepower   OK turning the motor CW and the intake valve opens...   Dec 9 2003, 07:02 PM
trojanhorsepower   That is really sweat, 58 views and nobody wants to...   Dec 10 2003, 04:57 PM
thesey914
  Dec 11 2003, 12:58 PM
trojanhorsepower   OK I know that I am not being clear. Brad no one w...   Dec 11 2003, 01:31 PM
trojanhorsepower   Marks up Piston up   Dec 11 2003, 01:34 PM
Brad Roberts   Damn.. now I need to leave...DOH! B   Dec 11 2003, 01:34 PM
trojanhorsepower   Rotate 180 deg. CW piston is down intake is slight...   Dec 11 2003, 01:36 PM
Brad Roberts   Pushrods are not sitting in the lifters correctly....   Dec 11 2003, 01:36 PM
Brad Roberts   I rotate the engines over on their side when I dro...   Dec 11 2003, 01:38 PM
trojanhorsepower   damn try again   Dec 11 2003, 01:39 PM
trojanhorsepower   These pics are not helping. I am going back to th...   Dec 11 2003, 01:44 PM
Brad Roberts   Check the push rods............ B   Dec 11 2003, 01:46 PM
trojanhorsepower   I went and pulled the rocker arms and checked the ...   Dec 11 2003, 02:16 PM
Jake Raby   Sounds like you are starting at "overlap" not at "...   Dec 11 2003, 02:19 PM
Brad Roberts   CW facing the fan or CW facing the flywheel ? B   Dec 11 2003, 02:19 PM
trojanhorsepower   CW facing the fan   Dec 11 2003, 02:26 PM
Brad Roberts   Correct. It sounds like you are not starting at nu...   Dec 11 2003, 02:30 PM
trojanhorsepower   Brad, Jake Thanks for all the help guys. I will ...   Dec 11 2003, 02:39 PM
Brad Roberts   The fan turns CW while facing it. In the car.. I g...   Dec 11 2003, 02:42 PM
Jake Raby   We are confusing him.... the engines motion is cl...   Dec 11 2003, 02:53 PM
trojanhorsepower   OK I went out and spun it again looking at #3 Sti...   Dec 11 2003, 02:58 PM
Jake Raby   If that happens turning it CW and all the pushrods...   Dec 11 2003, 04:58 PM
trojanhorsepower   Sorry guys, I was called away form the computer. ...   Dec 11 2003, 09:11 PM
Jake Raby   My number is 706 219 4874. I'm here till 3 Am ...   Dec 11 2003, 09:14 PM
trojanhorsepower   Running home to get cell phone (free long distance...   Dec 11 2003, 09:18 PM
Jake Raby   Try to ring me again...... I heard you beep throug...   Dec 11 2003, 09:50 PM
Brad Roberts   I still say pushrods. b   Dec 12 2003, 12:24 AM
Jake Raby   Told him to triple check them.....   Dec 12 2003, 09:48 AM
Gint   SO?!?! The 914 Soap Opera. Don't kee...   Dec 12 2003, 11:00 AM
trojanhorsepower   I have been away for a while, sorry it has taken m...   Dec 12 2003, 06:04 PM
- Lo-Fi Version Time is now: 13th June 2026 - 05:02 AM
