| JOE M |
Oct 22 2007, 11:20 AM
Member ![]() ![]() Group: Members Posts: 293 Joined: 27-August 07 From: N.H Member No.: 8,042 Region Association: None |
I cant seem to align my passenger door.What gives? Bassically the door overhangs the back of the door jam at the bottom(see pic).I do not think that there is any body flex that is causing this problem. There are 6 bolts that hold the door on. I have moved these all over the place and the door will not align. It closes but not quite correct. Any ideas on what I should do.
I did close the door,remove the top and roll the window up and down with no binding. That is why I believe there is no body flex. Also the longs look solid. Any advise would be greatly appreciated. ![]() |
| TravisNeff |
Oct 25 2007, 04:02 PM
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 5,082 Joined: 20-March 03 From: Mesa, AZ Member No.: 447 Region Association: Southwest Region
can you give us a photo of the car
From the rear of the car, along the passenger side so we can see the profile of the full passenger side of the car, taken while kneeling down. from that we can see how far off the door and the rear quarter is. |
JOE M CANT ALIGN PASSENGER DOOR. Oct 22 2007, 11:20 AM
rick 918-S Pull the rocker cover and take a couple more photo... Oct 22 2007, 11:49 AM
Vacca Rabite Door alignment can be a PITA.
Did the door fit ... Oct 22 2007, 12:20 PM
JOE M
Did the door fit... Oct 22 2007, 12:30 PM
McMark Was the door always like this? Looks to me like t... Oct 22 2007, 12:27 PM
roadster fan My 73 passenger door is similiar, doesn't stic... Oct 22 2007, 12:37 PM
angerosa I know it's of no consolation but my passenger... Oct 22 2007, 01:28 PM
JOE M
I know it's of no consolation but my passenge... Oct 22 2007, 01:34 PM
Todd Enlund
I bought the car a month ago. Not sure what the p... Oct 22 2007, 02:59 PM
JOE M
[quote name='JOE M' post='959598' date='Oct 22 20... Oct 23 2007, 05:39 AM
neo914-6 Take some diagonal measurements of an aligned door... Oct 22 2007, 03:28 PM
rhodyguy there is a major problem with the driver's sid... Oct 23 2007, 08:23 AM
JOE M
there is a major problem with the driver's si... Oct 23 2007, 08:56 AM
Vacca Rabite Depends on what you want out of the car. You can ... Oct 23 2007, 10:00 AM
1970 Neun vierzehn Joe,
You will need to determine the extent of you... Oct 23 2007, 10:53 AM
cooltimes Joe,
Color looks great. Where in NH? There is a su... Oct 23 2007, 11:10 AM
JOE M
Joe,
Color looks great. Where in NH? There is a s... Oct 23 2007, 11:32 AM
cooltimes Leave the top on to do the big butt test. That is ... Oct 23 2007, 12:30 PM
JOE M Here is a a little bit better picture of the door.... Oct 24 2007, 05:45 AM
Vacca Rabite The bottom pic is the underside of the car, right?... Oct 24 2007, 07:38 AM
JOE M [quote name='Vacca Rabite' post='960164' date='Oct... Oct 24 2007, 07:57 AM
Jeffs9146 It looks to me like someone did rust repair becaus... Oct 24 2007, 12:04 PM
Vacca Rabite :agree:
Jack point delete usually means some sort... Oct 24 2007, 06:23 PM
JOE M Sorry for my ignorance but does that mean that mea... Oct 25 2007, 05:43 AM
jd74914 Your door probably won't align perfectly right... Oct 25 2007, 09:49 AM
JOE M
Your door probably won't align perfectly righ... Oct 25 2007, 10:35 AM
tdgray Joe... to be a little more specific on what the gu... Oct 25 2007, 12:29 PM
Jeffs9146 Depending on how extensive the rust was or is will... Oct 25 2007, 12:56 PM
jd74914 What does the gap on the front of the door look li... Oct 25 2007, 01:06 PM
JOE M
What does the gap on the front of the door look l... Oct 25 2007, 01:20 PM
TC.356 OK, what if . . .
Figuring that you're not g... Oct 25 2007, 02:20 PM
rjames
:agree:
Probably a long shot, but is there an... Oct 25 2007, 02:21 PM
JOE M
:agree:
Probably a long shot, but is there a... Oct 25 2007, 03:16 PM
JOE M
From the rea... Oct 26 2007, 05:29 AM
craig downs That pic of under the car looks like the car was s... Oct 25 2007, 11:56 PM
roadster fan I think Craig is talking about these spots. In th... Oct 26 2007, 12:25 AM
rhodyguy the guys may be on to something with the sectionin... Oct 26 2007, 07:57 AM
Vacca Rabite Seriously, the car looks good. So long as you can... Oct 26 2007, 09:00 AM![]() ![]() |
Lo-Fi Version | Time is now: 2nd April 2026 - 12:40 PM |
