> a weber problem. one carb only, 40idf
rhodyguy
post Oct 27 2007, 08:45 AM
i'm stumped. at idle, i get a pulsing of fuel out of both of the accelerator pump jets on the pass side carb. they do not not leak with the engine off, with the key in the first position and the fuel pump engaged. driver's side does not exibit this. it occurs whether the linkage is hooked up or not, and the engine is idling. valves adjusted. i've been thru the setup proceedure repeatedly. side to side carb flow is balanced.
give me some ideas. the actuating arm is not bound on the cam and moves freely. so...incorrect float adj? stuck diaphram or one of the check balls missing or stuck? looking at the cutaway diagram on p58 of the cb book shows a good view of the circuit. there can only be so many issues.
i contacted the outfit that rebuild my carbs. their diagnosis was tight intake valves and the back pressure upon compression was forcing the fuel out. that didn't make any sense to me.
k
Thack
post Oct 27 2007, 09:49 AM
I think you have a hole in the diaphragm. Then air pressure pulls fuel out of the jet.
- Lo-Fi Version Time is now: 3rd July 2025 - 08:44 PM
